Road King Sissy Bar
Old Jun 7, 2012 | 01:33 PM
reloader-51's Avatar
reloader-51
Stage III
Default Road King Sissy Bar
HI All, New to the forums and have a question. I just bought a new 2012 Road King with factory seat and bought the factory docking kit for the sissy bar and luggage rack. Problem is, I need to get the sissy bar further back to get more room for my rider. Dealer says can't do it. Can anyone suggest possibly an aftermarket item that will fit and do what I need?
Thanks!!
Old Jun 7, 2012 | 01:45 PM
kingultra's Avatar
kingultra
i dont think you can do it either because the bar hooks to the shock.... Beware if you have soft bags (not sure about the hard) The docking hardware will hit the top of the bag and create a circle imprint
Old Jun 7, 2012 | 03:01 PM
TKDKurt's Avatar
TKDKurt
Sure does.
Old Jun 7, 2012 | 03:12 PM
Pumba11's Avatar
Pumba11
A detachable tour pak is actually more adjustable. Of course with the right, expensive aftermarket parts.
Old Jun 7, 2012 | 03:14 PM
blarg's Avatar
blarg
HD makes a kit to address that by stopping the lit from opening that far - it's a modification to the lid hinge - why they don't just build the leather bags that way to begin with....I've wondered that myself.
Old Jun 7, 2012 | 03:17 PM
Ghosteh's Avatar
Ghosteh
Thanks!!
Might be easier to modify the rider.
If you're REALLY needing to get the passenger backrest set further back, you might want to think about modifying the stock backrest, or having a talented fabricator make a new bracket that moves the pad back more. I used to own a really cool (but oddball) bike that I had to make/modify accessories to fit. It was a challenge, but it can be done.
Old Jun 7, 2012 | 03:18 PM
son of the hounds's Avatar
son of the hounds
It would probably be simpler and less costly to take the bar to a metal frabication and have it cut, extended the distance back you need, rewelded, ground, polished and re-chrome plated.
or
Take your sissy bar to the metal fabricator and tell them you want the same thing only (?) inches further back then have it painted/chromed.
Trying to screw with the mounts will likely end up being ugly and costing just as much but limiting and functionality down the road for other stuff.
or and I am not recommending this, get a smaller riding partner or join weight watchers.
Old Jun 7, 2012 | 03:25 PM
HazyHog's Avatar
HazyHog
Mine is a 2011 RKC. About a year ago I had a welder cut the sissy bar, add a piece of bar to each side and then weld it back together. It works perfect and made a big difference. It cost about a hundred for the modification and is worth every penny. Cost to either powder coat or rechrome is extra.
Old Jun 7, 2012 | 03:28 PM
longrideshields-1's Avatar
longrideshields-1
Premium Sponsor
You could also change the amount of padding on the back rest to a minimum but it might only buy you an inch.
__________________
General Inquiries:
Info@LongRideShields.com
Sales and Marketing:
Sales@LongRideShields.com
Phone:
775.331.3789
Old Jun 7, 2012 | 03:51 PM
blackjeep's Avatar
blackjeep
had same problem. put sissy bar in solid vice with some soft wood on either side and proceeded to bend it back. gained the !.5 or 2 inches of space i was after. Not easy but I'm a big M***** f*****. Try it...I dare ya...
