Deceleration Popping
PS - I have never had a dyno tune. Don't plan to either
Luckily the beauty of TTS Mastertune allowed me to eliminate the popping exactly as the manual suggests. By enrichening (lowering) the AFR between 1500 and 3500 RPM in the 20kPa column by 5-10%.
Richard, Is the kPa on the TTS the 20% throttle position or does it mean something else?
Or the Lambda table. Depending on your bike.
kPa is also displayed on the Closed Loop Bias table.
The percent TPS is seen during the VTune process when you try to get the cells green.
On the AFR table it is 9 columns (20-100kPa) x 17 rows (750-7000rpm). The AFR table is one of the 1st things you set. To Stoich.
The TTS manual is on their web site. P 57 displays the AFR Table.
Check it out. Lots of pictures, lots of tables. It only begins to make sense after reviewing the manual 5-6 times.
http://www.mastertune.net/files/calibrations.asp
You should see HD Motorcycle Files on the right side.
Delphi, assuming your bike uses Delphi
Manuals
Master_Tune_Tuning Guide-v133
Once you start tuning the bike you work with the VTune table.
This displays % TPS x RPM. P 65.
Keith said if we had to go over 40 then he would had sent me a new map.
