Vanishing Headlight
Old Jun 11, 2012 | 01:00 PM
Blind Man's Avatar
Blind Man
Stage II
Default Vanishing Headlight
Have an '05 RG. While riding at nite, I went from low beam to high beam & lost all lights. Replaced blown fuse and it's good. If at highway sped I go from low to high beam it blows. High to low has no effect. Also, while at idle speed or stationary, low to high or high to low has no effect. Any ideas? about a year prior to this event, i changed a headlight bulb. other than that, nothing electrical has been touched. Thanks.
Old Jun 11, 2012 | 01:40 PM
pswomack's Avatar
pswomack
Friend of mine had the same problem on his 05 RG, The fix was to change out the connectors for the headlight assembly on his, thats where i would start looking, if they are discolored or have a burnt smell like his did, change them. Hope this helps.
Old Jun 11, 2012 | 03:24 PM
longrideshields-1's Avatar
longrideshields-1
Premium Sponsor
As mentioned above, check the connections. sounds like something is shorting it out, maybe only does it when you have the vibration of highway speed? I'd look for frayed wires while you're at it. Had this problem with an atv. turns out the vibration was enough to shake the connectors loose at the light and short it but only when the atv was at speed.
__________________
General Inquiries:
Info@LongRideShields.com
Sales and Marketing:
Sales@LongRideShields.com
Phone:
775.331.3789
Old Jun 11, 2012 | 03:28 PM
eathomps's Avatar
eathomps
Check the wires closely from the bulbs back about a foot. My guess is you pinched a wire when reinstalling the fairing. This can cause it to blow the fuse in a somewhat intermittent manner. Don't ask me how I know.
Reno007
Electrical/Lighting/Alarm
Apr 19, 2017 10:47 AM
Veekness
Sep 29, 2014 07:26 AM
MichiganDave
Jul 25, 2012 09:01 PM
locodude
Jul 28, 2011 08:43 AM
CSI
Sep 14, 2006 11:32 PM
