Best Tuner
Old Jun 15, 2012 | 01:32 PM
Mimo951's Avatar
Mimo951
Thanks for your replays...
The prob. Is that there is no one can have the dyno in my area & no one can tune it for me
thats why am looking for the auto tune, plus i dont know much about the tuning thins. I want somthing basic i can deel with it
Old Jun 15, 2012 | 02:01 PM
lionsm13's Avatar
lionsm13
Use whatever your tuner uses and has had the best luck with.
If you don't have a tuner in your area go to a rally.
You'll generally find a good one or two there.
Old Jun 16, 2012 | 09:00 PM
raiderrick's Avatar
raiderrick
5th Gear
i got the power commander set up with v&h hhead pipes and cfr pipes screamin eagle k&n cone air filter! got it dynoed too! runs great!
Old Jun 17, 2012 | 05:13 AM
Mimo951's Avatar
Mimo951
Do i need to change the headers...
Am thonking of removeing the CAT only
Old Jun 17, 2012 | 12:12 PM
XARAN's Avatar
XARAN
You dont need to buy headers , but they will work better than the stock head pipe even with the cat removed. But removing the cat is better than leaving it in.
I understand that you dont have a mechanic that can tune / dyno. So IMO call Jamie at Fuel Moto and based on your budget look into either a PCV or a Power Vision. Fuel Moto will send it to you with a preloaded MAP based on your bike and you should be set. If it needs a little "tweaking" that can be done with help from Fuel Moto, if you can send an e mail you can load and send MAPs for the PC or Power Vision.
Im running my current bike based on a MP from Fuel Moto and no Dyno Tune and it runs great.
Old Jun 17, 2012 | 01:48 PM
primdl's Avatar
primdl
New pullback handlebars will help too...
Old Jun 17, 2012 | 02:03 PM
TUCCI's Avatar
TUCCI
??? did I miss something???
Old Jun 17, 2012 | 05:20 PM
one-up's Avatar
one-up
Dyno-Jet has a new model of tuner called Power Vision. Appears to be very flexible, adaptable and easy to use.
Something to check out.
Old Jun 17, 2012 | 05:27 PM
dondee's Avatar
dondee
Just got one.
Love it!
Old Jun 17, 2012 | 06:14 PM
RKLeo's Avatar
RKLeo
Not one SERT vote?
