525 lbs. bottoming out
Old Jun 18, 2012 | 12:59 PM
shadybiz11's Avatar
shadybiz11
6th Gear
Default 525 lbs. bottoming out
Hey all,
I weigh 300 lbs and the wife weights 225lbs. We ride with our rear suspension at 40Lbs. of air. It's quite comfortable until we go over that bump in the road and bottom out the suspension. Any ideas, other than losing weight, as to how we can improve the ride?
Old Jun 18, 2012 | 01:10 PM
1flhtk4me's Avatar
1flhtk4me
Have you tried 50lbs. which i think is the max.?
Sometimes you just cant avoid bumps or holes.
Old Jun 18, 2012 | 01:12 PM
XARAN's Avatar
XARAN
Your right around the max recommended weight. If your bike is 09 or newer go to 50psi, if that doesnt work out get better shocks that will carry the weight
Old Jun 18, 2012 | 01:13 PM
LaneG's Avatar
LaneG
Ohlins
Old Jun 18, 2012 | 01:56 PM
RHillbilly's Avatar
RHillbilly
Progressive 940s stopped mine from bottoming out
Old Jun 18, 2012 | 02:34 PM
dbell66253's Avatar
dbell66253
+1 on new shocks....
Old Jun 18, 2012 | 02:37 PM
hog95023's Avatar
hog95023
If you buy ohlin shocks i dont think you will find a spring that will offer a good ride solo and 2 up. I would call howard
Old Jun 18, 2012 | 02:39 PM
Texas Fat Boy's Avatar
Texas Fat Boy
2008 and older bikes I believe you are at the max.
All these new Harley touring riders will tell you 50 lbs, but that's for 2009 and newer bikes.
HD changed the shocks when they changed the frame in '09.
Old Jun 18, 2012 | 03:09 PM
Bill03E's Avatar
Bill03E
Change the oil in the shocks you have , I would try 15wt, you should be able to lower your air pressure that way. it will feel a bit harsher though.
I have 10wt in mine and run about 25-30 pounds, 2 up.
Bill03E's Avatar
Bill03E
I have 7wt in mine and run about 25-30 pounds, 2 up.
