Air compressor recommendation
Old Jun 19, 2012 | 11:29 PM
mccstevie's Avatar
mccstevie
Default Air compressor recommendation
Can anyone recommend a small,quality air compressor to pack on the bike. Saw a small Slime model for $15 today but looked pretty cheap. If I gotta haul it,it better work when I need it.
Old Jun 20, 2012 | 12:16 AM
CHILLLS's Avatar
CHILLLS
i got the HD one, ya i paid more but what ever. comes in a pouch so it wont get beet up in the bottom of the bags. havent used it yet.
think i paid $35 for it.
Old Jun 20, 2012 | 12:38 AM
mkguitar's Avatar
mkguitar
the slime's fitting will not fit on my current bike, works fine on the older bikes--- and with touring space at a premium it is small.
I figure I'll make up a hose adapter so I can use the slime on the new bike.
mike
Old Jun 20, 2012 | 12:49 AM
VINNIE JAMES's Avatar
VINNIE JAMES
i have a j&p hand pump. same as HD. think it was $15cheaper. used it twice
Old Jun 20, 2012 | 04:43 AM
aviscomi's Avatar
aviscomi
I carry the Slime model, works fine on both my bike 2010 & 2012 SGs
Old Jun 20, 2012 | 04:59 AM
DuraGlide's Avatar
DuraGlide
I have the Slime one. Little slow on tires, works great on the air shocks if you need to add a little air on the road tho. Mine has worked both times I've used it and it fits pefect in the lowers glove box.
Old Jun 20, 2012 | 05:41 AM
HDV-GLIDE's Avatar
HDV-GLIDE
http://www.amazon.com/gp/product/B00...ls_o00_s00_i02
Do some researching, this is what I have and it got good reviews on a few of the sites that test MC accessories, helmets, etc...In operation, it doesn't jump & bounce around on the ground like other units.
Old Jun 20, 2012 | 05:50 AM
RK Joy's Avatar
RK Joy
I got the H-D one. The pouch fits the hard bag perfectly, it plugs into the battery tender pigtail, has a built-in light and has a little extension hose to make it easy to use under the bike.
Old Jun 20, 2012 | 06:26 AM
Fastmover's Avatar
Fastmover
5th Gear
Go to a bicycle shop and get CO2 cartridges and an inflator. It will take 4 or 5 cartridges to inflate a mc tire. Much more compact to carry.
Old Jun 20, 2012 | 06:37 AM
flhxkiller's Avatar
flhxkiller
I went the CO2 route also, got the larger size only need to pack 2 of them. If I get a flat tire thats enough to fill it once I use my plug kit that is also needed if you plan on doing the repair on the road.
