need advice
Old Jun 20, 2012 | 09:52 AM
99%er's Avatar
99%er
I did the same thing once. Bike ran better again after I siphoned out the 87. Very easy to siphon it out takes about 2-3 minutes. Replace with 93.
Use the 87 for your lawnmower or dump it in your car tank or whatever else uses 87 well.
Old Jun 21, 2012 | 10:57 AM
lickalotapuss's Avatar
lickalotapuss
1st Gear
thanks when i get home today im going to changes plugs and ride the hell out of it (the motorcycle) not the old lader if u were wondering
Old Jun 21, 2012 | 02:09 PM
icepick's Avatar
icepick
+1 on the screen name....best one I have seen yet.....as to your problem, maybe you drooled in your tank at last fill up and have stopped up your fuel filter
Old Jun 21, 2012 | 10:07 PM
X Iron Butt's Avatar
X Iron Butt
Coulda been high octane druel. happens ya know!
Old Jun 22, 2012 | 03:18 PM
Theakerr's Avatar
Theakerr
Anytime I get a problem like yours, where it points to gas although as others have said gas normally does not result in the problems you mention, my 1st fix is to add gas line antifreeze, a concentrated amount FI cleaner and go for a run to get rid of the old gas. If that doesn't work, you go from there
steelerdude1
Jun 24, 2013 09:03 PM
Brettfullthrottle
Sep 22, 2012 04:30 PM
blake cunliffe
Jun 20, 2012 12:54 PM
beerun
Road Trips
17
May 30, 2010 09:19 PM
ridzalot
Aug 17, 2009 07:51 AM
