online discount HD dealer is usually 20% there are a a half dozen so shop around.
no manual ****, idle speed is programmed into the ecm.
minimum idle 1000 rpms ( oil pressure and volume are rpm dependent so a higher idle is good- also tailpipe emissions are lower at a higher idle) idle is often higher 12~1300 rpms.
Late models can get confused if the motor is shut down with the throttle slightly open.
cycling the ign. switch on until the fuel pump stops/ off/ on until the pump stops etc. 4 or 5 times ( with hand OFF the throttle) will reset the "zero" for the idle and throttle position sensor.
On start up ( cold) my 09 will often run up to 1700 for a moment before settling down.
My '53 will idle at 650, but the old motors are completely different- the exterior "shape" is about the only thing shared with the twin cam
mike
Screws and ***** are gone now you need a key board. I run my idle at 975 with no observed loss of oil pressure and I find bike has better parking lot manners with a little lower idle.
I adjusted mine with power vision. Many flash tuners will. I was Not looking for cam lope for me it feels better and bike has better parking lot behavior. @ 1k idle i felt pushed along in idle @ stop lights it always felt a tad too fast of a idle.
