Idle adjustment
Old Jun 20, 2012 | 04:05 PM
iclick's Avatar
iclick
Flash-based tuners like Power Vision, TTS, and SEPST can adjust idle--to a point at least. Some ECM's force a limit on how far down you can go, as the lowest recommended setting is 900 rpm supposedly to retain adequate oil pressure. I have mine set to 950 (originally 967) and it is fine there. I did try it at 850 rpm, so the '07 ECM will allow it to go that far, but it only idled rougher and without any hint of that old "potato-potato" lope we now recall in our distant memories. My old carbed Evo RK did it at 875 rpm, but I don't think it's even possible with an EFI bike regardless of how low you set the idle.
Old Jun 20, 2012 | 04:58 PM
Texas Fat Boy's Avatar
Texas Fat Boy
Originally Posted by W.P.
............................Is there a idle adj. screw or **** on a 2012 Limited ? What is the proper idle speed ? ........................
No and 900 to 1,100 rpms
Old Jun 20, 2012 | 05:34 PM
big TYME's Avatar
big TYME
I think my idle is alittle low. Runs about 800-900. I have an 06 SG and need to bump the idle up. Was looking around Behind the AC and noticed a set screw that did adjust the throttle cam thingy majigy. Anyone now if I can manually adj mine. Just put a fuel moto PC3 on bike and idle actually dropped alittle.
Old Jun 20, 2012 | 06:50 PM
ClassicBill's Avatar
ClassicBill
A good idle lope is possible with fuel injection it just isn't as easy to achieve.http://www.youtube.com/watch?v=MOuLP...&feature=g-upl
this is my bike idling at 1000 rpm
Old Jun 21, 2012 | 12:28 AM
W.P.'s Avatar
W.P.
Thanks for all the info.
Old Jun 21, 2012 | 12:50 AM
editbrain's Avatar
editbrain
You are suppose to adjust the butterfly by adjusting your throttle cables and the screw on the back of the intake.
But liked mentioned you will need to adjust the computer to adjust idle.
ultraclassic53
May 7, 2015 07:52 PM
nkfd13
Apr 1, 2011 12:41 PM
HDV-GLIDE
Mar 8, 2010 12:20 AM
halfbreed
Jun 8, 2009 08:04 AM
relli
Mar 3, 2007 03:34 PM
