Idle ???
Old Mar 7, 2010 | 05:07 PM
HDV-GLIDE's Avatar
HDV-GLIDE
Default Idle ???
Before I rip out the Fuel-Pac and purchase a PCV (which I'm sure your tell me to do LOL), I need to ask this question....
'09 SG, Pipes & A/F Filter...At idle, the RPM's (needle) fluctuates between 950-1000.....
Not sure if it did it before I installed the Fuel-Pac.....
I questioned V & H Tech Support and they said to increase the value of Mode#1 to 5 (initial value was 0 per the website for my model pac and bike set-up)
The increase to 5 caused the RPM's to fluctuate between 1200-1500.
Bike runs fine, MPG in the low 40's.....
Does the needle on your tach's fluctuate while the bike is at idle?????
Old Mar 7, 2010 | 08:19 PM
navyman's Avatar
navyman
Yes, a bit. Have you tried disconnecting the Fuelpak to see if it changes the idle?
Old Mar 7, 2010 | 08:25 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
950 -1000 sounds about right to me.
Old Mar 8, 2010 | 12:20 AM
emwolb's Avatar
emwolb
it should idle at the rpm's you stated yours does. the evo's and earlier models would idle slower, but you've got to remember, with the twin cam, the oil pump has to keep the bearings lubed, and the cooling oil jets below the pistons operating too. they would sound more "harley-esque" with the lower rpm idle, but the twin cam motors just idle a bit faster than the earlier models, if that's what you're trying to compare it with. and yes, they all idle around the thousand mark. a bit faster till it's warmed up. if it's your 09 streetglide, it's supposed to idle that way. the needle will bounce a bit. not to worry.
Seahorse
Feb 21, 2019 07:49 AM
ultraclassic53
May 7, 2015 07:52 PM
W.P.
Jun 21, 2012 12:50 AM
Willy G.
Apr 8, 2009 07:02 AM
Bagged Out
Oct 31, 2008 11:45 AM
