Progressive Shocks to Stiff
Old Jun 29, 2012 | 10:23 PM
IBGary's Avatar
IBGary
I have a set of 440s. They were too stiff. Life time watrenty, I sent them back. They put on lighter springs. I just took them on a 2,000 mile 7 day road trip. I'm very happy with them. Call customer service. They were great.
Old Aug 10, 2012 | 02:41 PM
mtclassic's Avatar
mtclassic
Originally Posted by mtclassic
I sent mine back for the lighter springs and still not happy. I have them backed all the way off and still don't have enough sag. They are not nearly as good as my 440's were. I personally think progressive dropped the ball on these. I'm 180 or so they are far to harsh on sharp bumps.
Just an update and a kudos to Progressive Suspension.
While in Sturgis I stopped by the PS booth that was set up at Rapid City HD and mentioned that I was not happy with my 940's as they were too stiff even with the lighter springs. They told me to bring my bike by and let them look at it. I did and they checked the sag and they agreed it was not quite right. They offered to change springs to a 13" spring that is used on standard 13" 440's to see if that worked better. They said if they did not to come back and they would do whatever they needed to do to make me happy. long story short the new springs make a night and day difference. Absolutely perfect ride.
Old Aug 10, 2012 | 03:17 PM
Stang951's Avatar
Stang951
How is the ride height now?
Old Aug 10, 2012 | 06:08 PM
mtclassic's Avatar
mtclassic
slightly taller but still lower then the stock ride height (this on an roadglide ultra). It is so much better over sharp bumps and regular road bumps and irregularities.
Old Aug 11, 2012 | 01:46 PM
lucky4jm's Avatar
lucky4jm
Stage I
I bought the 940s at progressive advise, I gave them all the information needed to make the best decision for me. My weight 175lb I ride two up 50% of the and time style of riding there response was the 940s. ok I get them and there stiff as all get out even at 0 preload I only get 1/2 sag!
I call them and they start back pedaling and say that the average rider weight is close to 300lb and I'm to light for these shocks. Well I did call them 3 times before I made my decision based on there suggestions and they should have down falls before I bought them. Now they want me to ship them back for a lighter spring on my dime and I won't even know if this will correct the problem totally. Progressive dropped the ball on these shocks they should offer both springs light and heavy according to your weight, to avoid extra cost and time spent on a $700 shock.
Old Aug 11, 2012 | 02:26 PM
traylestrat's Avatar
traylestrat
too |toō|
adverb
1 [as submodifier ] to a higher degree than is desirable, permissible, or possible; excessively : he was driving too fast | he wore suits that seemed a size too small for him.
• informal very : you're too kind.
2 in addition; also : is he coming too?
• moreover (used when adding a further point) : she is a grown woman, and a strong one too.
PHRASES
all too —— used to emphasize that something is the case to an extreme or unwelcome extent : failures are all too common.
Old Aug 11, 2012 | 04:32 PM
HarleyGyrene's Avatar
HarleyGyrene
Originally Posted by traylestrat
too |toō|
adverb
PHRASES
Old Aug 11, 2012 | 08:18 PM
mtclassic's Avatar
mtclassic
on the positive side they will fit in a medium usps flat rate box so shipping si not too bad and they have fast turn around. I agree tho that they know the springs are stiff for someone under 300lbs. I am extremely happy tho with the new 13" 440 springs.
ST8cruzin
Dec 31, 2015 04:41 PM
AlanStansbery
Dec 9, 2011 10:17 AM
Buggy teeth
Jun 10, 2011 06:35 PM
WVICEMAN
Nov 25, 2008 01:00 PM
speeder37
Aug 4, 2007 08:23 AM
