Ignition Tumbler problem
Old Jul 1, 2012 | 07:57 AM
Clean's Avatar
Clean
Default Ignition Tumbler problem
Ok, I messed up putting bars on my 2012 Roadglide, I think my ignition tumblers got misaligned, any ideals on corrective measures?
Old Jul 1, 2012 | 08:08 AM
rustybearing's Avatar
rustybearing
Get a flashlight and a flat bladed screwdriver. Look down into the switch and align the slots. Might take a while but it works. Don't give up, keep at it. Here's a vid from rocknrod. https://www.hdforums.com/forum/touri...uctions-2.html
Old Jul 1, 2012 | 08:25 AM
Clean's Avatar
Clean
Default Saw the video
Any way once my ignition is in the hole, nothing happens, I believe I have inadvertantly misaligned the tumblers, with this said does anybody know how to correct this problem. I think the tumblers may be 180 degrees off, but I'm not sure, please help.
Old Jul 1, 2012 | 09:15 AM
Wally's Avatar
Wally
Read the response from rustybearing. It's really not that complicated. It's not like there are ten tumblers to align.
Old Jul 1, 2012 | 09:25 AM
HTNHARD's Avatar
HTNHARD
It will click down once everything is alligned properly. The ignition wont pull back out.
Old Jul 1, 2012 | 11:03 AM
Clean's Avatar
Clean
Default I understand this is easy
I know this is easy, I've done this numerous time, however once I line up the tumblers and re-instal the ignition and turn the switch clockwise nothing happens...not sure what the problem is. Anyway, I can use a screwdriver turn the bottom tumbler and bam, my power is engaged and the bike runs like a champ. Confused, any advise would be great. Thanks
Old Jul 1, 2012 | 02:06 PM
Sparky73's Avatar
Sparky73
As you know, just because your ignition slides in, doesn't mean the tumblers are correctly aligned. Same thing happened to me cause I was too cheap to pay HD for their ignition tool. Take your screwdriver and rotate the lower tumblers only. Try left or right 180 deg. Don't spin them, just try each tumbler in a different position.
Old Jul 1, 2012 | 02:07 PM
7Sixpack7's Avatar
7Sixpack7
The "tumbers" should be aligned in the fork lock position. Also make sure the button on the bottom of the ignition switch is depressed. Should slide in and lock down.
Old Jul 12, 2012 | 06:34 AM
Clean's Avatar
Clean
Default Update
Thanks everyone, after an hour or so I finally managed to correct this ignition problem. I didn't think I was going to have so many problems installing my new Ape Hangers, anyway the *** pain was worth it. Ride safe everyone.
Clean
Warhorse Brotherhood MC
South Carolina
Old Apr 27, 2018 | 12:49 PM
TooTall4U's Avatar
TooTall4U
Unhappy 2010 Ultra Key start problem
When I lock my forks and return to unlock them the engine and all electrical system will not engage. I have to wiggle the key switch back and forth multiple times and it usually corrects itself. A Pain and a empty feeling when out on the road. Dealer replaced it once but the problem did not go away. Anyone else have this issue?
