Removing ignition switch instructions
Old Jun 16, 2012 | 01:38 PM
rocknrod's Avatar
rocknrod
Here is a video of the procedure:
http://www.youtube.com/watch?v=7-QBH1SFyzo
Here is a guy who did something different with the install tool:
https://www.hdforums.com/forum/6027110-post57.html
I have never used one.
Old Jul 1, 2012 | 03:25 PM
zoozoo's Avatar
zoozoo
Great video thanks
Old Jul 4, 2012 | 10:27 AM
wudwork's Avatar
wudwork
4th Gear
Default Ignition switch removal/reinstall
I just removed and replaced my switch. I somehow got the whole thing out of alignment but figured out what it takes. Here goes.
There is NO special tool to set or reset the system. Look at the rod that is attached to the switch. It has 2 "paddle" sections. To lock the handlebars, you turn the bottom/lowest padded counter-clockwise. To activate electronics, you turn the upper padded clockwise.
The following steps assume you removed the ignition switch yet somehow cannot get it back on and/or working properly.
1. Turn handlebars to left most position. If they are currently in leftmost position AND locked then goto step 3.
2. Insert slotted screwdriver (not phillips), maybe 6" long with a 1/4" width blade. Lower it all the way into ignition switch hole. At the bottom, turn it to the left till it stops. That should lock the handlebars. Again, to repeat, you want to reproduce the function of the LOWER paddle on ignition switch without moving the things the UPPER paddle turns.
3. At this step, the bars are locked left.
4. Try and lower the switch. It must bottom out while in the LOCKED position (left most). Lets assume it does NOT bottom out or perhaps you cannot get it to sink in at all. I removed the switch then reinserted about 1"; until the LOWER paddle aligned with the things the UPPER paddle turns. Turn the switch LEFT 1 click. Now try step 4 again and possibly repeat.
Another thing I learned. If you do NOT have the spring in place when doing above steps, you must lift the switch (after its fully inserted) about 1/4" up to simulate what the spring does. I found I could not unlock the handlebars until I lifted it up like this.
This works, I did it, No custom or fancy or special tools; just a simple screwdriver.
Hope this helps someone. Tom
Old Oct 30, 2018 | 10:52 PM
TooTall4U's Avatar
TooTall4U
Did all the things you mentioned. Everything feels good. Occasionally when I lock my forks and then unlock them the power dose not come on. I wiggle the switch and eventually power comes back. What could it be?
Old Dec 23, 2018 | 02:09 AM
Dany Richer's Avatar
Dany Richer
Stage I
Merci
Old Dec 23, 2018 | 11:15 AM
jimmmya's Avatar
jimmmya
I had the lock "pop" out at local Wallmart !! I went in bought a long screwdriver and a flashlight and after many tries " there is a lot of combinations" down in that hole !!
Old Dec 24, 2018 | 09:49 PM
OLD 96's Avatar
OLD 96
This might help.https://www.hdforums.com/forum/touri...h-removal.html
OOPs. A day late and a dollar short. My apologizes. Sorry. My bad. Hope all works out.
Old Sep 16, 2019 | 06:46 AM
Jawain Swint's Avatar
Jawain Swint
3rd Gear
Thanks Tom this really saved my butt on my 2020 Road Glide I know you helped more than just me!
shovelheadred
21
Feb 4, 2014 07:29 AM
aped06classic
Mar 11, 2009 09:18 PM
TMART
Apr 21, 2008 12:38 PM
UppercaseJC
Sep 16, 2007 06:05 PM
graydog
Jul 9, 2007 01:32 PM
