I buy my bulbs at O'Reilly Auto and they have been fine, I use the cover off the Harley one and slip it on the new bulb. O'Reilly has some different colors though...
SO...you can put different colored led bulbs?
what is the HD replacement bulb number? what would the # be at a auto parts store?
i thinking the led's would be a lot brighter...also
where can i get the light bulb covers
thanks, vinnie
If you are talking about the 4 gauges other than the tach and speedo, they take a 194 wedge base bulb. You can get colored one's at most auto parts stores and can order good LED versions from www.superbrightleds.com. If you order LED's, make sure they have a wide beam spread or you will just get a hot spot on the middle of the gauge face.
