Stock Bars - Riser? Adjustment?
Old Jul 11, 2012 | 07:35 PM
wu8always's Avatar
wu8always
Default Stock Bars - Riser? Adjustment?
so i can't swing paying for new bars right now, so i was wondering if the stock bars can be modified with some risers or some rigged up spacer of some sort.
i'm okay with the stock bar shape and hand position, but at 5'9", i could use the bars back to me by about 1-1/2" or so.
is there any way to do this without changing out the bars and getting longer cables, etc?
thanks.
Old Jul 11, 2012 | 07:41 PM
TUCCI's Avatar
TUCCI
What model bike you got WU, most Touring models have some kind of movement adjustment?
Old Jul 11, 2012 | 08:59 PM
wu8always's Avatar
wu8always
it's an 07 street glide.
Old Jul 12, 2012 | 10:39 AM
Joe12RK's Avatar
Joe12RK
I rolled my bars back about that amount the other day. I don't know about SG but on a Road King you just loosen two screws that are hidden under a plastic cover. Made enough difference until my new bars go on.
Old Jul 12, 2012 | 10:43 AM
Trial dog's Avatar
Trial dog
You should be able to roll them back but this will lower them as well. Also, watch for tank clearance. I don't think you can put risers on without different fairing parts - but that's from memory without looking it up.
Old Jul 12, 2012 | 11:46 AM
XARAN's Avatar
XARAN
You cant use risers without loosing or modifying the cover. But a lot of times it makes a big difference to pull the bas back to the rider. Just remove the plastic cover and loosen the clamps and pull the bars back towards you. be careful that you still have clearance in full lock right and left between the bars and your tank console. Also dont forget to adjust the lever position because as you pull the bars back the levers will point more upward so usuall you want to turn them back down
Ashnic
Jun 30, 2017 09:14 PM
clap
Sep 10, 2014 03:27 PM
Tank27949
Jul 15, 2013 07:16 PM
crawly
Jun 1, 2010 01:05 AM
Fearless1
General Topics/Tech Tips
Jan 29, 2008 01:45 PM
