Stupid oil change question
Old Jul 15, 2012 | 07:27 PM
  #41
Verbal's Avatar
Verbal
Will an A/C Delco oil filter wrench fit the grooves on a HD filter? I'll prob use the K&N filter next.
Wish Mobil1 make oil filters for HD. My oil analysis on my truck when using the Mobil1 filters are exemplary!
Old Jul 15, 2012 | 07:42 PM
  #42
stuart1270's Avatar
stuart1270
Originally Posted by Tinman265
I have been using an AMSOIL filter (Eao134 this is the black # Eao134C for chrome). It is a little smaller in diameter and I have had no problems with getting it on and off. I have never used a Harley filter so I don't know of any sensor issues. Harley filter wrench will not fit on it (waste of money).....
I have the Harley oil filter catcher...... another waste of money.... I like the frezzer bag and the tin foil ideas! Thanks!
I also have the harley oil catcher. I found the trick to it. Put the oil catcher in place then slowly loosen the filter until the oil starts to flow then loosen a little more very slowly. This way the oil does not flow over the oil catcher. Works every time for me.
Old Jul 15, 2012 | 10:30 PM
  #43
North Star's Avatar
North Star
You know, I'm guessing K&N has a patent on their oil filters with nuts on the end, or else everyone else would have copied it by now.
Such a simple idea that works great- easy to remove and it even allows you to torque the filter to the specs they give you (2 nm I believe) which I like because once I tried to just hand tighten it and it ended up being too loose because it leaked.
Old Aug 12, 2012 | 01:27 PM
  #44
Idaho_Biker's Avatar
Idaho_Biker
Stage IV
Default Oil Change Headache, Never
Well on My Scooter ('75 FXE), I opted for the Custom Oil Filter (CCI-Chevy Type/Chrome of Course) that is Mounted from The Front Lower side of the Engine Mount. (an Added Benefit to this Location is as a Secondary Oil Cooler)
When I change Oil it is Easy: I slide a Pan Under the Filter, Remove the Filter, Drain, Install a New Filter, add New Oil, and I'm off for a Putt...
I added a Magnetized Oil Drain Plug on my Oil Tank, and about every 3-4 Oil Changes I get a Small Dixie Cup, Remove the Plug, and Look for any Metal, Clean, & Re-Install, Piece of Cake
On My Dresser ('04 Screaming Eagle): I installed a Wing-Style Valve in Place of the Oil Tank Drain Plug, attached some Tubing, & ran it down to the Under side of the Bike, and Once again the Old Drain Pan, slide it under, fill it, shut off the Valve, slide it out, add Fresh Oil, Back on the Road Again
Old Aug 12, 2012 | 04:43 PM
  #45
Glockmeister's Avatar
Glockmeister
For a "Stupid oil change question" this thread was actually a good read of technique and opinion.
Old Aug 12, 2012 | 04:51 PM
  #46
Chunker's Avatar
Chunker
I actually use the filter wrench to tighten the filter. By hand turn the filter until it just touches, back off 1/2-3/4 turn, install the filter wrench, and turn 1 turn. That gives the filter 1/4-1/2 turn after gasket contact. I still spill some oil when removing filter. Will try the 2 liter jug at the 20K.
Old Aug 12, 2012 | 05:30 PM
  #47
R Hill's Avatar
R Hill
I am new to this bike. Just put on a ultracooler. I plain on using large pliers like I always have. Filters I have read about filters. Put on filter hand tight using a little oil on gasket
The link is great info on filters.
http://www.calsci.com/motorcycleinfo/FilterXRef.html
I am hoping the following filter will fit my 07
[3]
These Oil Filters
have 3/4" x 16tpi threads,
8 psi by-pass valve,
anti-drain back valve.
and are about 3" / 3.5" long
Recommended filters first. Available filters include
Purolator PL14476 / PL14477
Mobil1 M1-102
Bosch 3330
Walmart Supertech ST4967 / 4386
Bottom of choices
AMSOil SMF 133/134/135
Baldwin B33 / B37
Fram PH4967
Hastings LF410 / LF 413
NAPA 1394
Purolator ML16822
WIX 51394 / 51396
kpb46
Jan 7, 2014 11:04 PM
tmultra
Mar 4, 2010 09:04 AM
tcfamy
Oil Archive (no new posts)
Dec 23, 2008 07:23 PM
petdoc94
May 11, 2008 08:28 AM
Lil Truckr
May 25, 2007 04:37 PM
