I am not picky about fuel mileage but wanted to know if 34 mpg on my 99 eg standard is normal, it is a carb also. I have had a couple sportsters and just came off a v star 1100 silverado that was getting 46 mpg, this being my first big twin was curious. Thanks
My 99 EG Standard (FLHT) with SE Air Cleaner, SE Performance II mufflers, SE 203 Cams, Larger Mikuni Carb would get high 40s and sometimes 50+ mpg on lazy country roads keeping it 55 and under and not wrist-happy. On the highway, over 70mph would drop to mid to high 30s.
My bone stock 08 FLHTC averages low to mid 40s across the board.
My 01 Road King which should get similar mileage averages 44 MPG. Have had as high as almost 49 and as low as 37 but that was some shitty gas. If this is a new to you bike try running some Techron fuel system cleaner through it. Then let us know how it goes.
Those are almost exactly the same numbers I have with my 12 RK. 49.2 has been the max, so far.
2011 RKC 103 and Dynoed.
1 up City - 33. Mixed - 36. Highway - 41(70mph +)
2 up the numbers really don't change much.
I don't shift till 3000, and don't go into 6th gear till about 65mph.
Bike runs great.
Cannot really accurately compare later injected bikes with earlier carbed models in most cases. The Screamin Eagle insert came with the Screamin Eagle air cleaner kit, which was the filter and backing plate. A carburetor modification is something different and USUALLY was a Thunderslide kit, but not always. Sometimes nothing was done, other times jets were replaced or even drilled out. To tell if it has a Thunderslide kit, remove the air filter and look down the carb throat. If the slide is black plastic, then it has the Thunderslide kit. Those kits were pretty adjustable, including the metering rod length. If the plugs are pretty black it may be running too rich, also look at the muffler outlets if they are sooty black.
When I installed a Thunderslide kit in a 1200 Sportster I had years ago, the directions I followed as far as the jets and settings turned out too lean and I had to richen it a bit by lowering the metering rod clip a slot or 2. I would bet, if you do have the Thunderslide kit, the rod might need to be raised a slot and see how that works out. Raising the clip to a higher slot allows the rod to sink farther in the jet and leans it some. If I am remembering the directions right.
Thanks for the info, I will check tonight when I get home and yes the pipes are dark and a little sooty. I race cars in the SCCA, have a x Busch road race car and know how to tune a Holley carb, never messed with these before, the only issues running wise is after a long highway run, 20 miles or more the idle goes up about 300 rpm when coming to a light or stopping, then in stop and go traffic will settle down after a while to 900. It will set a 900 after warm up but again go up 300 after a long run, tried to adjust it but is to low after it settles down after a long run, not sure what to look for, am sure I need to get a manual to learn about these carbs.
