My 2005 Road King Classic has recently developed a problem .While cruising engine cuts out for a brief moment then runs fine.This initially happened on a long run ,did it once and not again for couple of runs later. Yesterday it did it 3 different times than was fine for about a half hour than died completely Started right back up and was fine for the rest of the day. No codes,checked all obvious connections. Not sure if its fuel or electrical .Any ideas?
Mine did that 3 or 4 times when it was newer. Like missing 1 power stroke. Then run normally for days or weeks. Finally quit doing it. Musta accidentally fixed it doing normal maintenance like cleaning and tightening battery cables, changing fuel filter, etc, or it fixed itself. Hasn't done it in a couple of years or so.
No codes ,Gonna change fuel filter and inspect fuel lines,then start checking electical connections Ill keep you posted Thanks for the input,any other ideas are welcome
Also pull and clean fuses, apply dielectric grease ! And give your ignition switch a shot of Jack Daniels....the alcohol cleans it and leaves a protective coating.
