Engine cutting out
Old Jul 25, 2012 | 02:21 PM
NPW's Avatar
NPW
Yep...just went through this with my 07 Dyna. Take the fuse cover off, start the bike ,and gently wiggle the system relay and EFI control relay. If its like my Dyna, the bike will miss/and or die. This is a common enough problem that I carry those two relays in the tool kit.
Old Jul 25, 2012 | 02:32 PM
highmarket's Avatar
highmarket
Originally Posted by raymac
My 2005 Road King Classic has recently developed a problem .While cruising engine cuts out for a brief moment then runs fine.This initially happened on a long run ,did it once and not again for couple of runs later. Yesterday it did it 3 different times than was fine for about a half hour than died completely Started right back up and was fine for the rest of the day. No codes,checked all obvious connections. Not sure if its fuel or electrical .Any ideas?
Mine did that same thing, turned out to be a wire harness to rear injector, no code, later found out to be a recall memo sent to dealers only.
Old Jul 25, 2012 | 03:21 PM
XSKIPRO's Avatar
XSKIPRO
Sorry didnt read the whole thread but you should check your main relay.
Beside the fuse panel.
Mine did exactly what your saying then stopped altogether.
No codes were thrown but it shuts down the fuel and ignition system. Started right up afterwards but then all of the sudden nothing.
$5 part and I wasted a day on the trailer because of it.
Good Luck.
Old Jul 25, 2012 | 09:21 PM
PaPa-Oakie07's Avatar
PaPa-Oakie07
Stage IV
Had this happen to me on a 1200 mile trip. Engine would cut out for short time then take off again, did this 4 times in the last 600 miles. With the help of forum members I narrowed it down to the system relay fuse 8 dollar part and running like new again
Old Jul 26, 2012 | 07:05 AM
EasternSP's Avatar
EasternSP
Had these same symptoms on my 06RG several weeks ago while riding back from central PA to VA. Just a couiple times but enough to catch my attention. Checked the wiring and air filter. Changed the fuel filter, checked the plugs, nothing really stood out as a problem. Rode it some more and it stuttered a few times. Took it to my mechanic. He rode it for a couple days but didn't experience the problem. I took it back and within a few days it stuttered again. Went through all the connectors on the throttle body and added injector cleaner and the bike ran fine for a couple days. Headed out last week on a ride from N. Virginia to N. Kentucky and the stuttering came up again but it got really bad to the point that the bike was only running on one jug and it sounded like it lost its tuning. I hauled the bike home in a U-haul truck and took it back to the indy. He rode it and experienced the problem so now he has something to work with. He changed out the crank position sensor but the bike still ran rough. Next item was the head temp sensor but I didn't want to hang around to see what he found. The bike has been there since Saturday but he hasn't called with a progress report, but then, I didn't really want a report except that he found the problem and fixed it.
Old Jul 27, 2012 | 10:26 AM
raymac's Avatar
raymac
Stage IV
let us know the outcome Im curious...Thanks
Rsmil
Feb 6, 2019 03:30 AM
GLIDEGASM
Apr 8, 2014 03:46 PM
flhtci2006
Mar 11, 2014 12:16 AM
kaathrin
Electrical/Lighting/Alarm
Jun 13, 2009 02:47 AM
draperjojo
Aug 31, 2008 10:49 AM
