Non working starter button
Old Jul 26, 2012 | 12:11 AM
green hd's Avatar
green hd
Default Non working starter button
The guy I bought my 99 Ultra Classic from said that he had had some starter problems, so he had a new starter put on it and had a plunger put on the starter to start the bike if the button didn't work. I find that more and more I have to use the plunger on the starter more and more. When I press the button, the radio dims badly. Maybe a grounded wire off the button? Pinched wire in the housing? I find it hard to believe that a Harley mech wouldn't have tried a new switch. Thoughts?
Old Jul 26, 2012 | 01:05 AM
mkguitar's Avatar
mkguitar
when the plunger is used - ALL the wiring is bypassed..the handlebar switch, the relay the wiring to and from etc. is bypassed--- only the battery cable is carrying power.
if you are having problems the battery is the first place to look.
take it out and have it load tested , at the same time clean and tighten the battery cable connections at both ends- make sure the cable isn't corroding inside the insulation- look for powder coming out of the insulation when the cable is tapped on a hard surface.
mike
Old Jul 26, 2012 | 09:22 AM
green hd's Avatar
green hd
mike
Damn it, guess I was over thinking it. Will look at the battery, Thanks Mike
Tommy-Law
Electrical/Lighting/Alarm
23
Feb 17, 2014 04:00 PM
Mr Haus
Nov 20, 2011 11:33 PM
anubisss
Oct 8, 2009 12:14 PM
neverdown
May 12, 2009 07:39 AM
PJsthnam
Mar 29, 2006 05:33 AM
