New grip question?
Old Jul 29, 2012 | 11:09 PM
Casper's Avatar
Casper
Originally Posted by So-Cal Street Glide
There should be a little slack between the end of the bars and the new grips. If you remember when you had the stock ones on you should have been able to pull/push about a quarter inch of free play between the bar and grips. I put the Avon's on my 11 SG and had the same issue until I backed off the grip just a little bit. I think this is what t.sawyer is saying as well or am i just babbling nonsense?
Tried moving the grips back, no help...loosened the screws, no help...it's like the bars are too big, but my stock HD grip works fine...even a set of Kury grips were tight....I'm about lost on this simple thing.....
Old Jul 30, 2012 | 12:23 AM
V2Evo96's Avatar
V2Evo96
Casper are you sure the switch control housings are properly aligned one to another and captured properly by the brake lever boss fitment?
If that Avon grip is a little bit 'proud' on the switch end, could it be binding on the switch control housing?
Old Jul 30, 2012 | 12:28 AM
Wanna Ride's Avatar
Wanna Ride
Originally Posted by Casper
I don't believe any,of the later models have the old star fast idle thumb star...my 07. 2010, 2012 do not...
My buddies '07 FLHX does have the throttle lock, but it doesn't have cruise. My '08 doesn't have the throttle lock, but it does have cruise.
Every HD touring bike I've seen built in the last 4 or 5 years - if it didn't have cruise, it had the throttle lock.
Old Jul 30, 2012 | 12:51 AM
Sparky73's Avatar
Sparky73
Guess that would explain why my 2011 (without cruise) does have a throttle lock.
Old Jul 30, 2012 | 01:50 AM
Casper's Avatar
Casper
well guys, didn't know about that...mine has cruise so no throttle lock...sorry. thought HD had done away with them. Duh!
V2Evo...I'll check again tomorrow....maybe remove it all and start over....
Old Jul 30, 2012 | 04:44 PM
So-Cal Street Glide's Avatar
So-Cal Street Glide
This may sound like a dumb question but did you get the right grips? I have noncable throttle some have a cable some don't, if you bought the wrong one it will never work. The cableless ones have a little gear/sprocket on the end of your bars and one inside the grip. make sure you have the right ones, they all look the same to me. Also make sure you are putting the right grip on your throttle side, they look the same but the one for the throttle has a hard plastic piece that your control gousing fits over. Good luck, let us know if you get it going..
Old Jul 30, 2012 | 04:52 PM
Rock Chalk's Avatar
Rock Chalk
this was the first thing i thought of too...or for whatever reason that gear/sprocket deal isn't catchign the TBW.
Old Jul 31, 2012 | 12:56 AM
Casper's Avatar
Casper
OK, I do have the right grips, and yep have to correct one on the throttle side ( the small gear that contacts the throttle inside).
I even removed the entire switch hosing, still doen't snap back...I'm lost.
I may go back to stock and just sell these....
Old Jul 31, 2012 | 07:00 AM
coujac's Avatar
coujac
I also have the 2 + 2 sweepers and I just changed from HD grips to ISO grips and the throttle does not snap back.
Old Jul 31, 2012 | 07:41 AM
Spur56's Avatar
Spur56
I have the 2+2 and Avon grips and they work fine now. They were a little tight when I first put them on and the throttle did not snap back. Put some dry graphite lube on and came back the next day and it now works fine. I think Avon has been getting some complaints about loose grips. They must have the tolerance down to minimum now. Could always tape some sandpaper to handle bar and the slide grip on and rotate some to remove a little material from the inside. Use fine grit. Hope you get it worked out, I love Avon grips.
