Deutsch Plug Removal
Old Aug 1, 2012 | 02:32 PM
FatAlbert's Avatar
FatAlbert
2nd Gear
Default Deutsch Plug Removal
I need to remove the Digital Gear Indicator that I fitted to my 2010 Road King Classic, but to do so, I need to remove the Deutsch plug from the wiring loom (so I can pull the loom back under the tank and through the mounting case on the handlebar.
So.....can anyone give some advice on how to remove the plug without destroying the connector pins and case?
Old Aug 1, 2012 | 03:08 PM
Rock Chalk's Avatar
Rock Chalk
i think it explains it in the manual....going to need a small hook to pull the white plastic piece out and then a tiny flat head screwdriver (what i used) to lift the plastic "latch" that is holding each individaul pin in. i'm sure someone can explain it better and likely has pictures. make sure to note which color wire goes to each hole.
Delta's Avatar
Delta
Here you go
Old Aug 1, 2012 | 03:37 PM
FatAlbert's Avatar
FatAlbert
2nd Gear
Brilliant video - I'll try tomorrow in the daylight but I'm sure it will work. Very many thanks
cajun1957a
Sep 15, 2017 03:40 PM
clovisrider
Electrical/Lighting/Alarm
Jun 20, 2015 07:58 PM
Alleyn
Dec 14, 2013 08:22 PM
big kal
Jan 17, 2013 02:16 PM
easyonmenow
Aug 29, 2009 12:55 AM
