Throttle Problem???
Old Sep 27, 2013 | 07:59 AM
  #31
harleybill1347's Avatar
harleybill1347
Stage III
took bike to dealer and will fix limp mode problem under emissions warranty if less than 5yrs. old and under 18,000 miles.
Old Sep 28, 2013 | 01:21 AM
  #32
Tirpitz's Avatar
Tirpitz
Just traded in a 08 Ultra Classic with over 65,000 miles and never had a problem with the TDW. And I used the low pressure washer at the local carwash and still the bike never gave me any problems and always got me home. I hope the 2014 Ultra Limited has the same good luck.
Old Oct 30, 2013 | 09:28 PM
  #33
Redangryduck's Avatar
Redangryduck
6th Gear
hey guys 1st post...got a 2010 sg and i was having almost every problem mentioned with the tbw... ive done everything from dialectic grease to changing the 6 pins on the throttle body and my scoot ran like crap like the bike was getting vapor lock or clogged fuel filter..anyway bit the bullet and got the screaming eagle kit that DOESN'T have the green connector in the handlebars..its a little confusing to wire up cause the wires change color at the connector but everything you need to know is on this site..take your time..my bike runs great now got a little over 1000 miles since the swap and running like she should...hope this helps
Old Oct 31, 2013 | 07:08 PM
  #34
Nute's Avatar
Nute
Service bulletin out from MOCO for this exact problem. You'd think by now HD would have a recall with the number failures occurring.
Service Bulletin for this is TT418A. Came out January 7, 2011. Google it and you should be able to get a copy. If not shoot me an email and I will fwd it back to you. Too big to post in
Old Oct 31, 2013 | 07:41 PM
  #35
OwnerOfHarriet's Avatar
OwnerOfHarriet
might need to replace the pins -- they also have an updated module for them - my buddy did both
Old May 1, 2014 | 10:27 AM
  #36
tjbluehogharley's Avatar
tjbluehogharley
2nd Gear
Hi did you ever fix your bike and what was the solution?
Pat3
Jul 7, 2016 12:17 AM
jamala00
Aug 31, 2013 10:57 PM
jdvorchak
Jun 19, 2013 10:11 PM
09rkpolice
Feb 9, 2013 08:03 PM
rshwetz
May 18, 2010 09:20 PM
