High pitched squeal
Old Aug 12, 2012 | 09:08 PM
Verbal's Avatar
Verbal
Question High pitched squeal
I'm starting to hear a high pitched squeal from the left, maybe from the front on mt 08EG with 23k. The closest thing it sounds like to me is the wear pad sensor on a car's brake pads. But since the HD pads don't have a sensor, what am I hearing? I'm thinking front bearing? It's not constant, just comes and goes.
Old Aug 15, 2012 | 11:39 PM
racinghoss's Avatar
racinghoss
I started having a similar sound in mine today. Mine is not constant, but only has a couple second gap between hearing it. Doesn't go away with the clutch pulled in and I dont hear it while stationary and idling. I am also thinking wheel bearing.
Old Aug 16, 2012 | 04:52 AM
Very High Plain Drifter's Avatar
Check the condition of your drive belt and sprocket. If they're misaligned, the belt can squeak and wear too fast. Have either of you had a rear tyre replaced, or anything like that?
A wheel bearing is more likely to be a sort of grinding noise, rather than a squeak.
Old Aug 16, 2012 | 05:25 AM
cochon's Avatar
cochon
Try to lift the front end up off the floor and spin the wheel by hand. You should hear the squeal if it's coming from there.
Old Aug 16, 2012 | 06:36 AM
pdzani's Avatar
pdzani
Mine made a high pitch squeal when moving, ended up being front wheel bearing.
Old Aug 16, 2012 | 06:38 AM
journeyman's Avatar
journeyman
Motor mount
Old Aug 16, 2012 | 06:49 AM
valvestem's Avatar
valvestem
My guess is wheel bearing,
Krazy8s
Jun 28, 2018 11:41 PM
tattoowho
Jan 22, 2015 05:03 PM
Galdog
Sep 27, 2014 11:03 AM
garslayer
Jan 21, 2011 09:03 AM
patsfan05488
Wheels/Tires
May 21, 2010 10:16 PM
