Light in dash
Old Aug 12, 2012 | 09:49 PM
tidbit1's Avatar
tidbit1
Default Light in dash
I don't ride much at night but got caught out last night and i notice that i have no light in the fuel gauge. Will that be a bulb out in the fairing or is it a fuse out???? Any help appreciated.
Old Aug 12, 2012 | 10:17 PM
Airborne350G's Avatar
Airborne350G
Most likely it is a bulb. It could also be just the prongs on the light are not set right. My would flicker and I removed the bulb and adjusted the prongs on the bulb and it is now good to go.
Old Aug 12, 2012 | 10:28 PM
steelhead's Avatar
steelhead
Very likely the bulb. Easy fix. You can do what some od us have done and replaced the stock bulbs with leds. More light and
Ast longer. Less than $20 for all four.
Old Aug 12, 2012 | 10:47 PM
stro1965's Avatar
stro1965
The bulb may have just popped out of the gauge housing.
Old Aug 13, 2012 | 01:36 PM
tidbit1's Avatar
tidbit1
That sounds great using LED's. Do you have a part # and where can i find them? I already have LED's on the rear with a Badlands Module. So i would guess i would be okay.
Thanks again guys.
Old Aug 14, 2012 | 08:09 PM
steelhead's Avatar
steelhead
Go to superbrightleds.com
If you search on that as well here you will get a lot of info.
I chose the WLED-AHP5. The A is for amber. The HP was the brighter option. No load eq needed.
Old Aug 14, 2012 | 08:40 PM
tidbit1's Avatar
tidbit1
Thanks for the info. I will check them out.
Old Aug 14, 2012 | 09:28 PM
TheLazyC's Avatar
TheLazyC
That is one good looking ride you have there. Exactly what we want, color and all. Hope to have it by spring.
Old Aug 14, 2012 | 09:30 PM
TheLazyC's Avatar
TheLazyC
I just placed my order for them after reading your post. I figured if I had to take it apart to check bulb, I just as well replace all of them while I was there.
traveler
Aug 30, 2018 02:14 PM
a99miata
Apr 23, 2014 10:39 PM
timvan
Sep 30, 2008 12:18 PM
kaptekarev
Panhead
May 19, 2007 03:22 AM
2006ultra
Apr 22, 2007 12:59 AM
