Non-Ethanol vs Premium
Old Aug 14, 2012 | 08:12 AM
rpeters282's Avatar
rpeters282
Default Non-Ethanol vs Premium
So, boys weigh in on this one. The only non-ethanol gas around here is 89 octane. That better than 93 ethanol gas? (always use 93, but the ethanol seems to gunk up carbs, etc.).
Old Aug 14, 2012 | 08:20 AM
NDBadlands4-2's Avatar
NDBadlands4-2
I try to NEVER run stupid ethanol. Try running the 89, if it causes knock problems look at octane boost, or keep looking for a different gas stations.
Old Aug 14, 2012 | 08:23 AM
Leftcoaster's Avatar
Leftcoaster
Ethanol does not gum up carbs, it actually cleans them. Problem is, most older carbs have parts that don't like alcohol.
If your motor pings on the low octane stuff, run it. If it pings you have no choice.
Old Aug 14, 2012 | 08:26 AM
RoadGlidinFreak's Avatar
RoadGlidinFreak
I'm surprised you can find any "straight gas" around Montgomery... I haven't found anything but the blended stuff around B'ham area.... I read somewhere (forgot where) that the epa is wanting to push a 15% mix instead of a 10%
NativeTexican's Avatar
NativeTexican
I will take non-ethanol any day over ethanol even if the ethanol has higher octane. I am sure that there are some people that love ethanol but I have not seen anything but problems since the government has forces us to use the stuff.
There has been millions in damages from ethanol just in the boating industry. From fuel tanks and lines that the ethanol breaks down.
I saw more than a 10% lose in mpg when switched over to ethanol.
This doesn't even take into account of the corn that is being taking away from being used as food or feed that increases the cost our food.
When they were first taking about going to ethanol I kept hearing that it was going to be cheaper for the price of gas keeps going and since mpg's are down we are jsut using more.
Old Aug 14, 2012 | 08:32 AM
roadking2014's Avatar
roadking2014
I get a little better mileage with 93 no ethanol but petter power and performance with 93 and 10% ethanol.
Old Aug 14, 2012 | 08:38 AM
larsfum's Avatar
larsfum
Try doing a search here. It lists ethanol free stations. If you find a new one, or one is no longer selling ethanol free gas please let them know.
http://pure-gas.org/
Most marinas will have ethanol free gas at a minimum of 91 octane, but you will pay for it. Thanks we only have 5-6 gallon tanks.
Old Aug 14, 2012 | 08:48 AM
vtwinbob's Avatar
vtwinbob
true dat!! i counted 11 in his area, just hope!!! he's close to one, http://pure-gas.org/index.jsp?stateprov=AL
Old Aug 14, 2012 | 09:30 AM
fwb35's Avatar
fwb35
In Virginia the stations that are E free are on the eastern costal area, the western part of the state or marinas, I was told all the stations in the 95 area and cities have to use E gas. When I race I take a jug and fill it with racing fuel and mix a little everyweek, I don't do it for performance or power, hi octane won't do anything for our bikes with low compression, you really should run the lowest octane you can without getting pinging, hi octane gas burns slower to prevent pinging in hi compression engines.
Old Aug 14, 2012 | 09:40 AM
Keithhu's Avatar
Keithhu
An example of the lunacy that has been caused by this ridiculous mandate:
http://www.cyrilhuzeblog.com/2012/08...l-blend-pumps/
