i got this info here on the forum that by jumpering pins 1 & 2 on the scanalizer plug under the right side cover then turning on ignition any codes would be displayed by flashes of the cel.
well i did that and all that happened was the check engine light flashed very rapedly , continuisly untill i turned off igntion.
this is a carbed model and the only reason i was checking was a carb pop at various rpms and mph . was wondering if i might have a intermitent crank sensor . any thoughts?
i have been through carb and this is a very low mileage bike.
