Tire pressure monitoring
Old Aug 16, 2012 | 07:50 AM
sfckelley's Avatar
sfckelley
Default Tire pressure monitoring
Is anybody using Tire pressure monitoring systems like these:
http://www.eglidegoodies.com/id303.html
Looking for some feedback before buying.
Old Aug 16, 2012 | 08:26 AM
Texas Fat Boy's Avatar
Texas Fat Boy
I've had the 3rd one down for about 40,000 miles (on three different bikes).
It works, but not as instant as I would like. It has a motion sensor to shut off the units on the valve stem when not in use. Sometimes it turns back on before I get backed out of the garage, sometimes it takes about a minute or two driving down the road.
You will be shocked at how much the air pressure increases once the tires get warmed up (4 to 6 lbs.)
It does work to check your tires every time you ride. Even when it doesn't turn on for a while (until you are down the road) it's enough to know you need air when you get back home.
It does seem to be pretty accurate too.
I paid a lot less than that though.
Amazon Amazon
Old Aug 16, 2012 | 08:28 AM
Texas Fat Boy
I just used some velcro and stuck it on the dash.
The first couple of years I had a strap around the switch in case it fell off, but it has never gotten loose.
Old Aug 16, 2012 | 08:42 AM
sfckelley's Avatar
sfckelley
Great, thanks! I like the key fob mount, was wondering about that placement too.
Old Aug 16, 2012 | 08:49 AM
Texas Fat Boy
FYI: I also use this tire gauge. It reads the air pressure while you are putting in the air or using the relase valve to lower the pressure. No more add some air then check, add some air then check, ect ect.
Amazon Amazon
Old Aug 16, 2012 | 09:05 AM
sfckelley's Avatar
sfckelley
Nice, appreciate your help!
Old Aug 16, 2012 | 09:12 AM
TUCCI's Avatar
TUCCI
Theres a market for just about any kind of aftermarket equipment and if $ was no option, I would have a lot of stuff and probably overpay for most of it. However, my $ tree is bare and have to chose wisely and tire pressure monitoring will involve using a tire gauge before taking the bike out or at least once a week. But dont let me poopoo on your fun....spend away and I will enjoy it vicariously.
Old Aug 16, 2012 | 09:33 AM
grbrown's Avatar
grbrown
Wink
I'm proposing to buy the top one. We have TPM in both our cars now and IMHO to be any real benefit it needs to be in view and to monitor continuously. I had a valve rubber on my Glide split in France last year and it would have been great to have just a little warning that the pressure was going down!
You can read more about some of those products here. There may also be a US site but I haven't looked.
Old Aug 16, 2012 | 09:59 AM
2AMGuy's Avatar
2AMGuy
Community Influencer
Ever wonder why everything has to be so high tech?
All of these gages are electronic and are a bit pricey for the average rider.
Why doesn't some make a simple, screw on air gage that works like the old fashioned "stick" gages?
Full pressure (above 30) the the gage could be color coded GREEN, the once the pressure drops 30#'s the stick could be color coded Yellow, the less than 20#'s, the stick could be color coded RED.
Fully extended, the stick, from the top to the valve stem would be RED, YELLOW then GREEN.
Perhaps there's one already available and I just haven't seen or noticed them.
Old Aug 16, 2012 | 10:16 AM
Nute's Avatar
Nute
Somebody has come up with these. They can be purchased from Canadian Tire in store or online and I am sure they are available in the States at "Wally Mart" or other auto parts stores.
For example http://www.bikebandit.com/bikemaster...indicator-caps
