Help needed with engine tune
I own a 2008 Road King with Stage II, as follows.
- 103 CI Big Bore
- Flat Top Pistons
- 255 CAMS
- SE Heavy Breather
- VH True Duals
- Rinehart Mufflers
When the bike is warmer the problem reduces but the bike now hesitates and stutters around 2,500 rpm when held constant with little load (not lugging). The bike still accelerates and pulls well when you give it gas.
Occasionally a "Front O2 Sensor Low" diagnostic trouble code gets thrown and the plugs are very white in color.
The bike had a professional dyno tune about 2 years ago. It dynoed at 107 ft lbs torque and has run very well for the past two years. This new condition is sudden onset without any changes or modifications being made to the bike.
On face value it seems like a lean running condition but I can't find any explanation as to why it would suddenly start running lean.
I have tried re-flashing the ECM with the dyno fuel map and just for kicks tried a stock HD fuel map that is closest to my configuration but that made absolutely no difference.
I have also looked for obvious problems like air leaks at the intake or exhaust manifold, but to my naked (and inexperienced) eye I see nothing that looks wrong.
The Harley dealer simply wants to dyno tune the bike again (at $450) to fix it, which I do not agree with. I'm sure they can reduce the symptoms by tuning them out but there is an underlying fault I want to find first.
I'm hoping someone can help me track the problem down.
I do have a 3 minute data dump from the ECM downloaded using the Screamin Eagle Super Tuner software that captures all the values from the engine whilst it is acting up. I don't understand the numbers well enough to know what they mean, however.
Can anyone help?
Thanks in advance.
- 103 CI Big Bore
- Flat Top Pistons
- 255 CAMS
- SE Heavy Breather
- VH True Duals
- Rinehart Mufflers
Can anyone help?
Thanks in advance.
Don't get me wrong, a good dyno tune is worth the money, but the problem is that very few know how to do it well IMO.
I also think that tuning shouldn't be used as a way to mask another problem. There are so many things you can adjust in the ECM that I have no doubt they could mask the symptoms I'm seeing, for example, by setting the AF super rich to compensate. But masking the symptom is not the same as fixing the problem!
I will try your starter fluid idea - thanks!
What I can do after swapping out the sensors is reflash the ECM with the original config. file - I'm guessing that the equivalent of resetting the ECM calibration.
