need help Trans fluid leak
Old Aug 26, 2012 | 10:00 AM
jerren25's Avatar
jerren25
Default need help Trans fluid leak
I replaced the clutch cable and unclogged the transmission vent tube and still got a ton of fluid up the cable. I added one quart of trans fluid when i filled it back up. Any thoughts?
Old Aug 26, 2012 | 10:03 AM
dawg's Avatar
dawg
Check the o-ring where the cable goes into the clutch release cover. Also, I'm assuming since you said 1qt you have a TC96 with 6 speed, yes?
Old Aug 26, 2012 | 10:05 AM
jerren25's Avatar
jerren25
Yes it is a 96 6 speed. I replaced the o ring when i put the new cable on.
Old Aug 26, 2012 | 10:58 AM
mkguitar's Avatar
mkguitar
so tranny is filled to correct level on dipstick, not overfilled ?
the end cover bolts are snugged to the new spec of 25 ft lbs ?
if the source of the seep is a mystery, spraying the area with drugstore fooot powder will help locate it
Mike
Old Aug 26, 2012 | 11:54 AM
stuart1270's Avatar
stuart1270
I have seen where the new cable is installed without the insulating braided shield at the tranny end and the cable came in contact with the bottom of motor and melted the vinyl causing it to leak.
Old Aug 26, 2012 | 12:07 PM
bagman1's Avatar
bagman1
It could be a leak between the cable end and the cable housing. If its dry around where the cable end with the oring meets the trans cover, than thats where your leak is coming from.
I have an 07 and it has basically seeped since it was new.
Old Aug 26, 2012 | 01:56 PM
jerren25's Avatar
jerren25
It is coming out of the adjuster in the middle of the cable
Da '04 RKC Kid
Jul 23, 2013 11:20 AM
Glide'n09
Apr 7, 2010 10:02 PM
jblair
Nov 1, 2009 09:41 AM
trampsinger
May 8, 2009 04:25 PM
RDKNGLVR
May 27, 2008 05:45 AM
