04 Road King fluid leak, need help!
Old Jul 23, 2013 | 10:27 AM
Da '04 RKC Kid's Avatar
Da '04 RKC Kid
Default 04 Road King fluid leak, need help!
I have a small fluid leak that I just can't track down. Not a big leak, but 1-2 drops per week. It's dripping off the clutch cable under the engine, but I'm having a problem finding where it's coming from.
Have recently changed all 3 fluids, replaced cam cover gasket (I thought that was the culprit, but it wasn't) and checked O-ring on clutch cable going into trans.
It was leaking the same amount before the fluid change, so that didn't cause it.
Any suggestions?
Old Jul 23, 2013 | 10:37 AM
big cahuna's Avatar
big cahuna
When I had my '96 cop bike, I had a leak just like you described. Turned out to be when the po installed a new clutch cable, he didn't route it the same as the original. From vibration , it wore a hole in the housing and started leaking trans oil. Easy fix , stupid reason.,,,
Old Jul 23, 2013 | 10:38 AM
mkguitar's Avatar
mkguitar
check that the tranny vent isn't blocked- if so, pressure builds up inside the tranny, forced the juice out. mud dauber wasps like the tranny vent.
to track the source of a seep/leak;
wipe down the area
spray the suspect area with drugstore foot powder, the powder will wash away at the source.
any fluid leaked is going to the lowest area, any wind action from riding can blow it around
Mike
Old Jul 23, 2013 | 10:59 AM
Da '04 RKC Kid
I'm going to have to check the clutch cable for this tonight. I'm thinking now this could be it, I've already had to have the throttle cable replaced after it snapped due to PO's routing of the cable when he put on the apes. I have braided stainless cables, though, would it still be possible to wear through the sheathing?
Thanks!
Old Jul 23, 2013 | 11:20 AM
bagman1's Avatar
bagman1
It could be your clutch cable sheave leaking at the crimp where it screws into the trans. Try the powder and see, my 07 did it, it seeped for years and was wet all the way up to the cam cover. Be sure you clean that area well, it can drip for weeks it seems like.
heavywear
Engine Mechanical Topics
Nov 10, 2015 10:17 PM
jerren25
Aug 26, 2012 01:56 PM
05Fatty
Jun 8, 2012 12:24 PM
Premont Harley
Oct 30, 2011 08:41 PM
jblair
Nov 1, 2009 09:41 AM
