I am sure this has been asked and answered, but I cannot find what I am looking for by using the "amazing" search link. I will apologize if it is repetitive or if I am asking in the wrong location. I have a 2012 Street glide. I am replacing all engine covers, (Primary, Cam, Top and side trans). I need to know if these are easy unbolt and bolt on or are they more involved. I am fairly mechanically inclined, but I think my name is from an Indian word meaning anything that can go wrong will. It appears from the manual, that the Primary cover should be fairly easy and straight unbolt/bolt.
I can tell from the diagram that the side trans(clutch) might be a problem. I know that there are three ball bearings in there and I can hear them hitting the floor and rolling away now.
The cam cover also worried me, because I have read post about holding up the lifters? Not sure why you would need to since pushrods stay put.
Has anyone done this? Any advice/tips would be greatly appreciated.
for the tranny end cover ( often called "trap door")- it is straight forward, and with the manual in hand you can figure out what to do with the ball and ramp mechanism.
here is my tip:
ONCE the trap door bolts are loosened slightly,
roll your tires up on a 2 x 4, and put the bike on the jiffy stand-- ensure that it is stable- get a Pal to balance for you if needed...
you can then pull the trap door without dumping fluid all over the floor, about a tablespoon will leak out.
when putting the trap door back on, the new torque spec for the bolts is 25 ft lbs
you'll have to remove the exhaust to switch the cam cover, having the exhaust off will also make it easier to get the trans trap door off. Remember to get new exhaust gaskets, and to pull out the old ones.
I'll have to keep this in mind for when I put my ceramic head pipe on. Might be the best time if I decide to make a change.
