Spotlights out
Old Aug 29, 2012 | 04:04 PM
TwoBlue02's Avatar
TwoBlue02
Default Spotlights out
Went for a ride Monday night and noticed my spots were out. Even the dash switch did not have a light on it.
I looked at the schematic in the manual. The only fuse I saw was for "lights" which I would assume was all the lights. Any ideas as to what the problem is and how to fix it?
Old Aug 29, 2012 | 04:16 PM
Lawdawg's Avatar
Lawdawg
Happened to me, turns out my switch was bad.
Old Aug 29, 2012 | 04:54 PM
mkguitar's Avatar
mkguitar
start at the switch, you may have a wire off OR did you leave the high beam on ?
mike
Old Aug 29, 2012 | 06:34 PM
TwoBlue02's Avatar
TwoBlue02
Switch could be it. The red light is not even on. Anyone else have an idea?
Old Aug 29, 2012 | 06:46 PM
wtb3886's Avatar
wtb3886
Check for a blown fuse then check the lamps.
Old Aug 29, 2012 | 06:55 PM
fishbust's Avatar
fishbust
When they went out on my 2006, I found a broken ground wire in one of the bulb housings. Had to drill out the rivot they used as a grounding point. I rewired with marine terminals and sealed everything.
Old Aug 29, 2012 | 09:30 PM
Nute's Avatar
Nute
Not to be insulting but check to see if your High Beam is on. Unless you modify the Passing Lights they only work when the Low beam is on.
exWinger
Jun 1, 2015 03:38 PM
kkinderen
2014-2024 Touring Models
Dec 8, 2014 01:14 PM
phil41
Aug 16, 2012 06:15 PM
Hrlyrider
Jun 27, 2010 02:08 PM
FOCI
Electrical/Lighting/Alarm
Jul 23, 2009 07:30 PM
