how hard???????
Old Sep 8, 2012 | 08:24 AM
rerelli's Avatar
rerelli
so you have to remove the compensator to change the stator ?
Old Dec 16, 2012 | 09:42 AM
teeboz's Avatar
teeboz
How in the...did you guys get the compensator nut off. I tried the breaker bar with extension and it still want bulge.
Old Jan 17, 2013 | 04:44 PM
WindJammer's Avatar
WindJammer
The compensator is secured with a bolt. With the outer primary cover removed (the chromed one), the compensator is the left hand sprocket (smaller one). It has a right hand (normal) thread. The compensator sprocket through a chain drives the larger clutch sprocket located to the right. The clutch is secured with a LEFT-handed nut - in other words to loosen you turn it clockwise (right). It is torqued to 160 or greater ft. lbs and with the breaker bar should come loose fairly easy - providing you're turning it the correct (right) direction.
Kristoffm
Jun 6, 2014 12:57 AM
W4MAC
Shovelhead
Apr 23, 2013 07:52 AM
RightSideShift
Ironhead
Jan 10, 2012 08:39 PM
buckup5
Mar 20, 2011 08:16 AM
fondew1@verizon.net
EVO
Aug 16, 2010 08:19 PM
