Tire Direction
Old Sep 6, 2012 | 05:02 PM
fat daddy's Avatar
fat daddy
Default Tire Direction
Hi all I was wondering if the yellow marking on a front tire has to go on the valve stem side and if it does does it make a difference what side the valve stem is on? Thanks
Old Sep 6, 2012 | 05:09 PM
journeyman's Avatar
journeyman
The painted on dot is intended to go at the valve stem for balancing(not always perfect). If a large amount of weight is needed, a good installer will move it away from stem and recheck, for a better balance with less weights.
The arrow dictates the direction the wheel must be turning.
Old Sep 6, 2012 | 06:01 PM
fat daddy's Avatar
fat daddy
I currently have 407 on my bike the yellow marking is on the right side as is the valve stem. Now I have an American elite tire and if I put it on the way the directional arrows point that puts the paint mark on the left . Now I now I can reverse the wheel and line up the valve stem with marking and the arrows pointed in the right direction but that will put the valve stem on the left side which is my question does it make any difference what side the valve stem is on ?
Old Sep 6, 2012 | 06:03 PM
busterdog's Avatar
busterdog
omg wtf
Old Sep 6, 2012 | 06:24 PM
Weavr99FLHT's Avatar
Weavr99FLHT
Follow the arrow, who cares what side the yellow dot is on? The valve stem causes the wheel to be out of balance, the yellow dot is attempt to mount tire in such a way to offset that.
Old Sep 6, 2012 | 06:59 PM
Jinks's Avatar
Jinks
The yellow dot indicates the LIGHT spot on the tire. It's placed at the HEAVY spot on the wheel. A good tire man will balance the wheel bare to determine where that is.
The valve stem goes on the RIGHT side of the bike. It's a lot easier to get to when the bike is on the jiffy stand.
The arrow points in the direction of rotation no matter which side the dot or the arrow are on.
Old Sep 6, 2012 | 07:11 PM
Neckball's Avatar
Neckball
..............and if you didn't have a yellow dot or any other color dot you can follow these directions and be sure that you have things mounted correctly.
4MercyMan
May 3, 2019 08:24 AM
shorty07ultra
May 23, 2012 06:16 PM
usefulshrimp
May 5, 2011 09:20 AM
albngore
Jan 8, 2011 02:26 PM
FotoDeville
Jun 8, 2010 08:09 PM
