re - tune?
Old Sep 7, 2012 | 03:28 AM
frozensoul's Avatar
frozensoul
Default re - tune?
ok my 2012 roadglide custom is stock except it has v& h twin slash slipons. stock air box. when i remove the cat from the headpipe will i need to retune or will the emc be able to adjust for it?
Old Sep 7, 2012 | 03:42 AM
jjnoble's Avatar
jjnoble
It will adjust. No need for a tune.
Old Sep 7, 2012 | 04:09 AM
scumBAGGER's Avatar
scumBAGGER
No......I took the cat out my 12Sg also with no tune and stock slipons....when you add air coming in you will need a tune....you are just letting it out not adding
Old Sep 7, 2012 | 04:20 AM
frozensoul's Avatar
frozensoul
scumbagger what kind sound difference did you hear after removing the cat?
Old Sep 7, 2012 | 06:58 AM
tbob's Avatar
tbob
Mine ran lean wih exact mufflers VHdresser duals . So i did a air cleaner and sert and
dyno.
Old Sep 7, 2012 | 07:43 AM
Johan96's Avatar
Johan96
Putting on notification
Old Sep 7, 2012 | 07:48 AM
Johan96's Avatar
Johan96
Interesting tread. I have headers with cat in, sest, air and have had it dynoed. Wonder if I have to retune after install with vance & hines power duals? Sorry not trying to hi jack tread, just an interesting case :-)
Old Sep 7, 2012 | 10:16 AM
TickTock's Avatar
TickTock
My understanding is that the adjustments are minor within a range. If you have a VE cell that is 97 at 2500 rpm and 20% throttle position the max adjustment is 10-15% of 97. For this discussion - the 97 is hardcoded into the cell and cannot be changed. Changes for the 10-15% happen in the adaptive fuel table which is the overall average of what is needed based on o2 feedback.
So for math purpose, lets use 15%. This will give you a variance of about 14.5 (97 plus/minus 14.5). If the cell needs 120 instead of 97 to be optimized it will never get there either in the original VE table OR the adaptive table. The adaptive table would have a max of 14.5 that gets added or subtracted.
So long story short - you may get away without doing a tune, but your bike will not necessarily flow through the RPM ranges and throttle positions smoothly. In addition the bike does not adjust well in areas that are being run in open loop which are basically the spaces where you twist the throttle.
Old Sep 7, 2012 | 10:42 AM
Afishinado's Avatar
Afishinado
I just did the swap out offered by American Custom (swapped stock header for stock header without the cat) on my 12 RG. You can hear a little difference, not much, but it definatley sounds a little louder to me. I am on the fence about louder pipes (again I will go with American Custom modifying stock slip ons. Pretty happy with the stock...
So now my question: Would like to get a little more out of the bike, pretty happy with it the way it is. If I do the slip ons and the V&H naked breather conversion, add a Power Comander, will I feel the difference?
Old Sep 7, 2012 | 11:41 AM
TUCCI's Avatar
TUCCI
About 1/4-1/3 more sound when I did mine......I would expect the same.
bigrobtemp
2014-2024 Touring Models
36
Aug 13, 2014 06:52 PM
bigrobtemp
Aug 9, 2014 10:33 PM
MachineX
Jul 24, 2014 07:00 PM
HDSAE60
Exhaust System Topics
Nov 25, 2013 10:41 AM
GEORGEW
Oct 7, 2009 10:22 AM
