How to remove Upper fairing?
Old Sep 9, 2012 | 11:50 AM
lnadler's Avatar
lnadler
Default How to remove Upper fairing?
I removed the 4 torx bolts and windshield screws, but couldn't get the fairing to lift off my 2006 CVO ultra. It seems the highway light bar is in the way. On you-tube I saw someone just lift it up and away from the highway lights, without removing them. I know the headlight wire is attached. Do I need to reach in and blindly remove the headlight wire? I want to install a connector to the headlight wiring to keep the highway lights on when the highbeam is on and would rather not pay the harley dealer an hour labor to do it. Any help would be much appreciated.
Old Sep 9, 2012 | 11:52 AM
FF4606's Avatar
FF4606
There are screws on the back side as well.
Old Sep 9, 2012 | 11:58 AM
Armstronges's Avatar
Armstronges
No. He got all of them. I had to drop the light bar on my ultra to get the outer fairing off to do the same mod your doing.
Old Sep 9, 2012 | 12:15 PM
Casper's Avatar
Casper
Never had to remove my passing lamps on any of my bikes....just reach around the fairing and remove the headlight plug...on the left and right side of the plug you will need to squeeze the plug to release it from the headlight bulb..hope that makes sense...reach around and squeeze the plug...may have to wiggle it a little...easy really...then lift the fairing up and away...
Old Sep 9, 2012 | 12:26 PM
mkguitar's Avatar
mkguitar
WAIT !
put a towel on your fender to prevent damage if something drops
put tube socks over the spotlights
pick out a soft place for your fairing AND your windscreen.
remove the windscreen- PUT the center screw back in loosely to hold the thing together
remove the 4 inner screws,
you can then remove the remaining screw while you hold the fairing, fingers is easier than using a tool
and as above just reach in and unplug the headlight
mike
Old Sep 9, 2012 | 12:30 PM
Pioneer74's Avatar
Pioneer74
Originally Posted by mkguitar
WAIT !
mike
Old Sep 9, 2012 | 12:53 PM
Fast Aire's Avatar
Fast Aire
Former Sponsor
Normally the fairing will come out by tilting it forward and then pulling it straight up & you can easily get the the headlight plug. But... Ive seen a few where the spotlights were closer to the fairing than others. If this is the case you can loosen the spotlight mounts to where they drop downward and out of the way. No reason to have to remove the spotlight bar.
Putting a towel on the fender is a smart move, many fenders have been dinged by a dropped fairing.
Old Sep 9, 2012 | 01:06 PM
Arvid's Avatar
Arvid
There have been times I have had to raise the left side(facing the bike from the front) to clear the highway light because of cable runs on the inside that have become pushed forward or sagging. No need to loosen the light bar. Follow everyones lead about protecting your fender and fairing paint from the backs of the running lights.
Old Sep 9, 2012 | 01:11 PM
Scaredofrain's Avatar
Scaredofrain
Same here on my Ultra. I cannot get the outer fairing of without removing the light bar. Put a good padding of (bathroom towels in my case) and rest the bar without disconnecting the wiring on the fender.
No use trying to squeeze the fairing through because it will not save time that way.
Old Sep 9, 2012 | 08:56 PM
lnadler's Avatar
lnadler
Thanks for the tips. I was able to wiggle the fairing away from the lightbar and removed it, nervously I might add! Glad I did- since I was able to accomplish my goal of adding the connector to keep the passing lights on with the highbeam. Also, zip-tied some of the loose wires. Droping the lightbar is probably the way to go though- since I was afraid I would scratch the fairing as I lifted it over the lamps. Thanks for the input!!
blackflame
Aug 11, 2014 07:54 PM
mastery
Jan 1, 2014 08:59 PM
garyglider
Dec 22, 2011 06:09 PM
07Eglider
Jun 1, 2008 07:44 PM
Softtail Bob
May 4, 2007 12:27 PM
