Electrical connection behind fairing?
Old Dec 31, 2013 | 06:34 PM
mastery's Avatar
mastery
Default Electrical connection behind fairing?
Wanting to hard wire a Zumo 660 onto my bike. Don't have much room left under the seat. I hear there is a connection point under the fairing "behind the headlight" that only has power when the ignition is on that would be available to use on my 08 Ultra.
Can somebody give me an idea where it's at? Is it supposed to be on the wiring loom that plugs into the back of the headlight, or in the mess of wires behind the headlight itself and closer to the frame of the bike?
Help a young'un with bad eyes, please...'cause I ain't seeing it...
Old Dec 31, 2013 | 06:41 PM
mkguitar's Avatar
mkguitar
look at the wire loom to the headlight, close to the headlight plug its a capped off orange/ white wire.
black is ground
mike
Old Dec 31, 2013 | 07:03 PM
mastery's Avatar
mastery
mike
Thanks Mike. I'll take a look in the morning when I pull the fairing. Sounds like a perfect place to run to.
Old Dec 31, 2013 | 07:17 PM
mkguitar's Avatar
mkguitar
you can just pull out the headlight and leave the fairing in place.
if you do remove the fairing
1.) plan where you are going to put it
2.) thick socks over the spot lights, THICK towel on the fender
3.) remove windscreen
replace center screw
remove fairing screws
the center screw now holds it all together- easy for you to balance the fairing and remove the center screw with other hand
then you pull towards you and unplug headlight.
and put the fairing down on the nice soft spot that you planned on in step 1
mike
Old Dec 31, 2013 | 07:26 PM
sanman4ever's Avatar
sanman4ever
Here you go
Attached Thumbnails Electrical connection behind fairing?-headlamp-wiring-1.jpg
Old Dec 31, 2013 | 08:41 PM
mastery's Avatar
mastery
mkguitar: thanks for the fairing removal writeup. I've had mine off at last a dozen times in the past five years (amp work, new speakers, new radio, new CB, new lights, install CB mount under the radio, etc) but I'm sure that will help somebody else.
sanman4ever: Yep, seen that. Didn't put 2 and 2 together, thanks for the photo. Not sure what kind of plug is on the end, but I imagine the best way to connect the Garmin is to cut and join the cables unless somebody know what part number I'd need for the plug to just put on the Garmin side.
Old Dec 31, 2013 | 09:59 PM
mkguitar's Avatar
mkguitar
just crimp a spade terminal on it.
I use that for power for my isimple iphone interface
re write up- I try to generalize for the next Guy.
I learn alot from other riders and reading their posts.
That wiring is for the Euro-spec "position light", which is a 5 w bulb inside the headlight housing.
Europeans sometimes use only a position light when in cities, the headlight low beam is focused quite close to the vehicle, and the high beam is "normal".
When a Euro headlight is used here ( such as the Hella "E-Code") riders often find that after they've aimed the low beam...tilting the whole thing up, the high beam lights up the tree tops.
mike
Old Jan 1, 2014 | 11:58 AM
klimoman's Avatar
klimoman
Was that connection added as simply an extra power source for an add on if needed, or was it designed specifically for something?
Old Jan 1, 2014 | 12:41 PM
mastery's Avatar
mastery
Sanman, found the connection in your photo. I take it positive goes there, and negative goes to ground like on the frame. Mike, I see it's a spade connection, so I'll spade it up. Thanks for the help.
Old Jan 1, 2014 | 12:43 PM
dawg's Avatar
dawg
It is there for International models that use it for lights
