09 SG burning oil?
Old Sep 11, 2012 | 10:10 AM
dirkpit222's Avatar
dirkpit222
Default 09 SG burning oil?
Hey all, I hv an 09 SG with SE heavy breather/Rush mufflers/download--all else is stock. Every 1000 miles(ish) I hv to add about half a quart of oil. No leaks anywhere, no blue smoke, plugs are normal color as well as exhaust pipes. Anyone have an idea where the hell my my oil is going?
Thx in advance,
Chris
Old Sep 11, 2012 | 10:17 AM
mkguitar's Avatar
mkguitar
if it is not leaking to the ground, and not leaking into the primary case ( see if the primary level is higher than should be)
oil does get consumed...incrementally ---it leaks past the piston rings, it is churned into an air/oil mist in the crankcase and vented into the intake- then burned. this is normal.
until you see smoke, keep riding.
burning oil makes WHITE smoke.
from the tailpipe on accel indicates piston rings not sealing- worn rings or mis-shapen bore ( worn)
from the tailpipe on decel indicates worn valve seal
mike
Glidedsternfan's Avatar
Glidedsternfan
Lightbulb Maybe...
You're over filling it by 1/2 of a quart.
Is there any oil in the air cleaner at the vent?
Maybe?
GSF
Old Sep 11, 2012 | 10:38 AM
dirkpit222's Avatar
dirkpit222
Mike..Thx, I'll check for white smoke on accel and decel.
GSF...I've been experimenting with this issue for some time now and definitely not overfilling. Did oil change at 7000 miles a few weeks ago and oil level was at proper line on dipstick when warm. Has gone down by half a quart and I'm now at 8000 miles. No oil coming out anywhere.
Likketysplit
2014-2024 Touring Models
34
Sep 30, 2016 07:26 PM
bbmfic
Nov 7, 2014 07:54 PM
kirby
Jul 25, 2010 09:04 PM
bonz
Jul 18, 2009 07:29 AM
lenny
Sep 9, 2007 07:11 AM
