Harley Batwing mini apes
Old Sep 12, 2012 | 10:53 AM
craigffb's Avatar
craigffb
Default Harley Batwing mini apes
Ok, it is hard as heck to find stuff searching on this forum. So I'm gonna ask.
Who actually has these on their bike (HD part # 57485-11 or 57474-11)?
I'm going with these bars and need to know if I can get away with using the OE upper brake line or not? It would help if you put them on and not paid someone to do it for you.
If I can, does the line need to be rerouted and if so how did you do it?
Thanks for the help.
And yes, I know I'll need a +4 clutch cable to keep it in the fairing.
Old Sep 13, 2012 | 03:01 PM
craigffb's Avatar
craigffb
Anyone?
Old Sep 13, 2012 | 04:46 PM
hatchetman's Avatar
hatchetman
No sir! What I had to do was cut my line & flair a 5 inch piece in where I could hide it in the top of the forks! I bought a braided line for a sink, cut the end off & gently pulled the braiding off. Than slid it over my brake line to cover the joint. Your only other option is buy the whole thing with both flex lines on it & 5 or 6 inches longer!
My original bars had dents put in them to allow for the wiring. These new ones did not so I used a dremmel to open the wiring holes on the switch blocks.
My old bars had the air reservoir in them. The mini apes did not. What I did was get 10 feet of air line & coil it up inside my fairing to act as an air reservoir!
Hatch.
Old Sep 13, 2012 | 04:53 PM
drukanfu's Avatar
drukanfu
I gott'em and love'em. Used all stock wires, cables and hoses. Still have plenty of slack with bars full left or right.
I routed my clutch cable through inside of the bike frame, wire-tyed loosely to make sure it stays away from the front jug. And the fairing, just put it on the inside of the fairing support bracket then through the fairing hole.
Pulls the same as before, no clutch adj. needed either.
HD 57474-11
Old Sep 13, 2012 | 06:25 PM
craigffb's Avatar
craigffb
HD 57474-11
Cool. I'm gonna go ahead and replace the clutch cable as I'm swapping out the side cover anyway. What did you end up doing for the upper brake line. Just move it a bit. I haven't takin the fairing apart yet. Still waiting on the maintanace manual. But it looks like there may be some slack in it once the OE zip ties are cut.
Old Sep 13, 2012 | 09:20 PM
drukanfu's Avatar
drukanfu
I just loosened the banjo nut up a frog hair, to move it out from the bar.
Old Sep 13, 2012 | 09:25 PM
craigffb's Avatar
craigffb
Sweet.
Old Sep 14, 2012 | 03:47 AM
mike5511's Avatar
mike5511
I guess I need to go by a dealer and see if they have some of these on a Ultra. I don't want to go above the fairing, but I've never liked the stock bars.
Old Sep 15, 2012 | 10:33 PM
craigffb's Avatar
craigffb
After taking a better look at the stock clutch cable I think I'll give a try at rerouting it. Looks like there is some room to stretch it out a bit by running it up the left down tube the way my Dyna is done.
Str33tgl1de
Jul 30, 2019 05:59 PM
RickK
Jun 24, 2019 08:29 PM
sixshooter
2014-2024 Touring Models
Dec 11, 2014 08:25 PM
dugan
Feb 16, 2013 10:52 AM
SinisterFLHTCI
Aug 9, 2012 05:08 PM
