The Jack has lost its... pumpability
Old Sep 16, 2012 | 08:44 PM
bcane98's Avatar
bcane98
Default The Jack has lost its... pumpability
I just moved back to the US from Germany, put my jack under my Ultra, but the upward movement was not right. The pump action is about 1/10 what it used to do before the move. I'm sure it was not flat in the crate, so there is a good chance the move screwed something up inside the jack... any suggestions?
Didn't get much in the searching area, but I am sure my search criteria was a bit off as well.
Thanks
Rick
Old Sep 16, 2012 | 09:03 PM
top0211's Avatar
top0211
It may have lost oil from the hydraulic cylinder; or been drained for the move. It may need to be refilled in order to build up the correct amount of pressure.
Old Sep 16, 2012 | 09:17 PM
jjnoble's Avatar
jjnoble
That would be my guess too.
Added: By the way, I like the new word, "pumpability". Keep using it, maybe someday it will end up in the dictionary. I'm going to keep it, I've already added it to my dictionary.
Old Sep 16, 2012 | 09:23 PM
davessworks's Avatar
davessworks
Last time that happened to my pump I just bought another pump for about $10
Old Sep 17, 2012 | 09:44 AM
larsfum's Avatar
larsfum
Either you lost oil, or you have air in the system. I would try bleeding the pump first, then try adding oil if bleeding didn't help. Do a Google search. Plenty of info on both.
Old Sep 17, 2012 | 06:11 PM
Verbal's Avatar
Verbal
I'm certain that there will be multiple definitions listed!
Old Sep 17, 2012 | 06:41 PM
DresserDude's Avatar
DresserDude
I like PUMPOSITY, however, I'm thinking it just needs the air bled out or some extra hydraulic oil. make sure the bottle is on a level surface (may need removed)
rjo3491
Jan 1, 2019 09:05 AM
gtrplyr
Apr 30, 2018 09:43 PM
BMyers
Feb 14, 2016 09:38 PM
Sledge Hammer
Feb 5, 2012 01:25 PM
South Jersey Scooter Trash
Jan 2, 2012 04:29 PM
