Another alarm
Old Sep 17, 2012 | 02:17 PM
HB's Avatar
HB
Default Another alarm
How can I do away with or shut down the alarm system? No matter what I do I still cannnot disarm with fobs. Tired of using the pin code. Can I put it in service mode somehow? Been all over the owners manual.
Old Sep 17, 2012 | 04:12 PM
dawg's Avatar
dawg
Can always change out the TSSM to a TSM, or swap with someone that doesn't have security. Basically, you have a 68922-00D and want a 68920-01D which is $147.78
Old Sep 17, 2012 | 05:54 PM
piasspj's Avatar
piasspj
Have you tried a new battery in the fob?
Old Sep 17, 2012 | 09:00 PM
Ohiobellboy's Avatar
Ohiobellboy
X2...buddy has a 2011 sergu that the battery went dead in one of the fobs.
Old Sep 18, 2012 | 03:20 PM
HB's Avatar
HB
Put new battery in one No change. I brought it home on a trailer. Did not know about transport mode when I bought it. Could this have caused the problem? Old owner said he never had a problem.
Old Sep 18, 2012 | 03:55 PM
piasspj's Avatar
piasspj
It could have and probably did run the bike battery down. Does your bike have a voltmeter? What model of bike is it? It would be a good idea to charge the battery and check the connections.
How is it the bike acting (how do you know the alarm system isn't disarming?) Do the signal lights flash when you move the bike (with the fob present).
What have you tried?
Old Sep 18, 2012 | 06:58 PM
okcjetmech's Avatar
okcjetmech
Yes you can put it in a perminate service mode........Based on the fact I'd read on another post how someone stated they had, had it done at the dealer...not sure if you can do it yourself...So the answer is MAYBE...........sorry had to
Old Sep 18, 2012 | 06:59 PM
HB's Avatar
HB
09 ultra Old owner had the fob in a kruzer kaddy. Bike fired right up when I test rode it. On the way home I noticed turn signals flashing. Put fobs in my pocket on the way home.Backed off trailer and it took forever to start. but finally did. Took to town made several stops and no problem. Next morning would not disarm. Turned switch on and off couple times with fob on seat. Fired up finally. was good for a couple more stops. Put new battery in one fob no change. Switched battery to other fob no change. Tried to put in transport mode and it would not work. I can manually disarm with pin. Luckily it was still at factory setting. Old owner had no idea when I called for the pin number. Unhooked battery tonight and bot busy so it is still unhooked. Hope I dont have to go to the dealer to get battery hooked back up and started.
Old Sep 18, 2012 | 07:54 PM
Ohiobellboy
There's other places than a dealer to get a battery and save a few bucks. I have only read where others have go to an auto parts store and been able to buy them.
jmr1971
Electrical/Lighting/Alarm
11
Jun 6, 2014 01:15 PM
GoPro Steevo
"The Florida Crew"
14
Jun 2, 2011 04:28 PM
oneway
Mar 14, 2010 02:07 PM
Hoffy49
Jan 12, 2010 06:55 PM
QS78
Aug 30, 2009 07:23 AM
