Gps usage??
Old Sep 18, 2012 | 04:47 PM
themensh's Avatar
themensh
I dislike that woman announcing directions over my MP3 music....oh, the GPS annoys also...
Old Sep 18, 2012 | 04:53 PM
12limited's Avatar
12limited
Default Audio OFF
I turn the audio off...i hate it when they tell me they are "Recalculating"... when I bail off route to some adventure.
I glance at the GPS as I do oil pressure and speed. I can read it as it says turn left in 3 miles.
Old Sep 18, 2012 | 04:56 PM
jerryleejr's Avatar
jerryleejr
I'm the same way, all the technology in the world and they can't figure out you want to make a pit stop...lol
JJ
Old Sep 18, 2012 | 05:39 PM
jerryleejr's Avatar
jerryleejr
I guess the issue was resolved for me, apparently the tray option won't work because it won't accommodate my iPhone in a case, so USB in the back it is.
JJ
Old Sep 18, 2012 | 06:01 PM
Chucks1911's Avatar
Chucks1911
I'm a look at the map guy too. I dont like that woman telling me where to go all the time. The GPS either
Old Sep 18, 2012 | 06:26 PM
FDHOG's Avatar
FDHOG
Originally Posted by HDRoadking_nc
I mute mine and just look at the map...
Same here. Have a Bluetooth earpiece, but seldom use it.
Old Sep 19, 2012 | 06:22 PM
we_brown's Avatar
we_brown
I plug mine into the aux port on the HK radio. I listen to the prompts, but also look at the map. It sometimes is extremely difficult to just listen only. You will get a voice prompt that says "bear right" on some road. You look at the map and the road is straight. Also, the wonderful "turn right then turn right" voice prompt can be a little confusing. Looking at the map helps. The voice prompts also let you know when you are close to a turn. It can take some getting used to.
Old Sep 19, 2012 | 07:40 PM
Tedjay's Avatar
Tedjay
I listen to voice instructions and verify by looking at the map. If I'm just out cruising with no particular destination I just use the map.
Old Sep 20, 2012 | 05:53 AM
grbrown's Avatar
grbrown
Talking
We have a bluetooth intercom, although I have never tried to tie it in to the gps. Mrs B can see it over my shoulder, so I get a running commentary when necessary! V effective.....
Old Sep 20, 2012 | 06:44 AM
CRocks's Avatar
CRocks
Originally Posted by waybo418
I currently use just the map, but at times the screen is very difficult to see due to the glare. The Garmin app may just be a viable option for me as well as I already have the hdpdplus.
Try one of those clear stick-on shields. They filter UV + make the screen much easier to see in direct sunlight.
