Security System Question
Old Sep 19, 2012 | 08:17 AM
NDBadlands4-2's Avatar
NDBadlands4-2
Originally Posted by ucommbxny
Maybe the security system is in transport mode
That is very possible. It will say in the manual how to turn off transport mode.
Old Sep 19, 2012 | 08:22 AM
shooter5074's Avatar
shooter5074
From: Western Illinois, land of bad roads, and corrupt politicians
With the fob present, turn the ignition switch to IGN to disarm the system. To cancel the transport mode, set the engine stop switch to RUN.
Old Sep 19, 2012 | 08:54 AM
Mike_M's Avatar
Mike_M
It's possible that the previous owner had the security system turned off.
If you search for it, you'll find that a number of people on this board disliked the security features and have had the dealership disable it.
You're probably going to have to go to a dealer in order to get it working if your bike is actually equipped with it.
Old Sep 19, 2012 | 09:27 AM
CRF's Avatar
CRF
well this would have been done cuz I've been riding the thing so that rules out transport mode...
the previous owner disableing it or the system never having been activated in the first place seem like the most logical things..... guess I'll have to go to the dealer and find out.
Old Sep 19, 2012 | 10:04 AM
shooter5074
Try this
1. With the ignition switch in the OFF position, turn the ignition switch ON-off-ON-off-ON
2. Press the LEFT turn switch 2 TIMES and release
3. Turn the ignition switch back off
If you have a security system, you should see the turn signals and indicators flash 2 times.
Old Sep 19, 2012 | 10:46 PM
CRF's Avatar
CRF
Hey thanks for all the ideas everybody..... I went to the dealer today and mystery solved...... The original owner, for whatever reason, never had the security system enabled... The dealer says it was probably an oversight by the original dealer and the guy didn't know his security wasn't working... Anyway it's all set up and working perfectly now.... Took 10 minutes
Old Sep 19, 2012 | 10:49 PM
murlsquirl's Avatar
murlsquirl
Wrote a long post and then realized you figured it out. Glad it was an easy fix.
Old Sep 19, 2012 | 10:51 PM
CRF's Avatar
CRF
Originally Posted by murlsquirl
They didn't install it. Happened to me last year...I got the FOBs too. Make sure you lock those forks until the dealer installs because there is nothing stopping someone from firing it up.
All good now... They got it all set up today
Old Sep 20, 2012 | 03:16 AM
HDCat's Avatar
HDCat
That's why this community is here, to equip us all with every possible option before we visit with the Stealer! Glad it worked out for you. Now enjoy your ride!
Old Sep 20, 2012 | 04:26 AM
skratch's Avatar
skratch
excellent. now make sure that you have set your own pin code, and know how to use it. it doesn't help if you set it but don't know how to use it.
GuitarKidd
Oct 9, 2018 06:55 PM
willshort
Sep 24, 2018 02:21 PM
etxabier
May 27, 2013 08:42 PM
jstew
Oct 28, 2010 09:53 AM
JonV
Mar 16, 2010 06:08 PM
