People with engine knowledge..
Old Sep 20, 2012 | 08:17 AM
2009blackpearle's Avatar
2009blackpearle
Default who took it apart
Who has it appart now dealer you or indy if it aint the dealer i bet they are gonna void warrantee
Old Sep 20, 2012 | 08:23 AM
mrwatson75's Avatar
mrwatson75
Dealer
Old Sep 20, 2012 | 12:25 PM
mrwatson75's Avatar
mrwatson75
So I went to the dealer and talked to the mechanic..the rods definitely stand up on their own. Also at the top of the rods the bushing(I think that is what it is) that the piston is attached to was turned..which means the top end was not getting oil. So basically the motor will be rebuilt or I will get a reman..that will be up to the warranty company..anyone know if I can put a CVO reman directly in? Looks like it is only 900 dollars more and includes the 255 cams which I was gonna have to spend 329 to get anyway..assuming I do not have to replace the throttle body..etc
Old Sep 20, 2012 | 01:34 PM
grbrown's Avatar
grbrown
I assume your bike is a stock 96? It looks as if this is all you have to do to install a CVO 103":
(Factory 103 and 96 to 103 upgrades)
Includes ACR (Automatic Compression Release). When upgrading an Original Equipment TC96 model to a TC103 displacement, separate purchase and installation of a model-specific Screamin' Eagle® ACR Wire Harness and recalibration of the ECM is required.
That adds a little extra expense, but it would be difficult to resist, if you can get a sensible deal under your warranty.
Best of luck in getting back on the road.
Old Sep 20, 2012 | 01:47 PM
mrwatson75's Avatar
mrwatson75
Actually it is a 103" FLHP..Thanks!!
Old Sep 20, 2012 | 02:34 PM
okcjetmech's Avatar
okcjetmech
Yeah a CVO will slide right in and you'll love it...
Old Sep 20, 2012 | 02:39 PM
mrwatson75's Avatar
mrwatson75
Thanks..I guess I will wait on the verdict..at least I have some choices..
Old Sep 20, 2012 | 03:12 PM
okcjetmech's Avatar
okcjetmech
What happened....did it just lose oil pressure on you or did it just crap out
Old Sep 20, 2012 | 03:23 PM
mrwatson75's Avatar
mrwatson75
Funny how it started..recently I started seeing oil blow down the right side..I noticed it while my neighbor was here. He looks at it and says he noticed a rocker box leak. There is one but i think most of the oil was coming from the air cleaner. Well while they checking things..I forgot the test...but it basically acted as if it was losing compression or not sealed well..so they called me to ask if they called tear into the top end..I said yeah it's under warranty..so when they did that they saw the rods in this state. I think the test was showing negative because the cylinders are now oval inside because the pistons have been wobbling around in there..you will have to excuse my ignorance..but the bike was running fine to me..I drove it over there when I dropped it off.
Old Sep 20, 2012 | 04:24 PM
okcjetmech's Avatar
okcjetmech
Wow sorry to hear that even if its under warrenty crap like that always ends in the MoCo's favor.....it would be the standup thing for the to just repalce the whole eng but. well when will you know what they are going to do?
Just a peice of advice. IF they decide to repair your engine, ensure that they replace every bearing and bushing inside the engine and document it. because if it fails again you want them to be aware "they repalce everythiing"
