People with engine knowledge..
Old Sep 19, 2012 | 06:11 PM
mrwatson75's Avatar
mrwatson75
Default People with engine knowledge..
This is mine now..I got the impression that there is a problem with the crank since the rods are standing straight..anyone confirm?
If so, I assume the cams will come out so I will have them put in the SE-255s..is there anything else I should upgrade while they are in there? Just better than OEM but not going crazy on funds?
Thanks for any advice!!
Old Sep 19, 2012 | 07:55 PM
2009blackpearle's Avatar
2009blackpearle
Default inner cam bearings
while cams are out I did the improved inner cam bearings on mine. U think about oil pump work, high flow pump or change oil pump bypass spring.
Old Sep 19, 2012 | 08:26 PM
drukanfu's Avatar
drukanfu
Old Sep 19, 2012 | 08:27 PM
Energy-Dude's Avatar
Energy-Dude
Looks like something is binding on the crank pin or rod bearings. They bearings should should be loose/smooth enough that they fall away from each other and lay against the engine case.
Old Sep 19, 2012 | 08:44 PM
okcjetmech's Avatar
okcjetmech
Thats what I was thinking....if you hold them up like they are and let go of them they should fall against the case......Looks like MO Money......
Old Sep 19, 2012 | 09:08 PM
mrwatson75's Avatar
mrwatson75
Thanks..that confirms what I understood the problem was..good thing it is under warranty..:-)
Old Sep 19, 2012 | 09:17 PM
mgmmgm's Avatar
mgmmgm
Default Miles
How many miles on it, what year?
Old Sep 19, 2012 | 09:19 PM
mrwatson75's Avatar
mrwatson75
around 11k, 2010
Old Sep 20, 2012 | 05:48 AM
grbrown's Avatar
grbrown
C'mon, you're asking us, with a poor photo, but what did the mechanic say when you asked him? Does he simply have some sort of support on the rods, so they don't rest on the crankcase mouths?
Old Sep 20, 2012 | 08:10 AM
mrwatson75's Avatar
mrwatson75
Thanks for the suggestions..I will look into them
