Ignition sequence for TTS after battery disconnect????
Old Sep 22, 2012 | 02:36 PM
Big Twi$t's Avatar
Big Twi$t
Default Ignition sequence for TTS after battery disconnect????
I disconnected my battery to work on my bike but I need the TTS Mastertune ignition sequence. IIRC, its recommended to go through this sequence after disconnecting the battery and before start up. I don't have my install instructions and can't find it on their website.
Any help? Thanks.
Old Sep 22, 2012 | 03:03 PM
golfblues's Avatar
golfblues
The sequence for Thundermax is run switch on, then ignition on for 30 seconds, off for 30, 3 times each. Ride.
Old Sep 22, 2012 | 03:16 PM
V2Evo96's Avatar
V2Evo96
The RevPerformance Auto Tuner procedure is what I think is the same as the service manual to reset the TPS (Throttle Position Sensor). My 09 Service Manual sayy:
With run switch on, ignition on 10 seconds then off 10 seconds-- repeat 5 times.
Try it-- can't hurt anything.
Old Sep 22, 2012 | 03:23 PM
hojones's Avatar
hojones
Cycle switch 5 times on and off.
tmilo1000
Nov 4, 2016 02:07 PM
AndyT
Mar 30, 2016 02:50 PM
ki7hy
Electrical/Lighting/Alarm
Aug 9, 2014 05:02 AM
Greg755
Jul 2, 2011 01:18 AM
Uncle Scrooge
Jun 4, 2007 08:43 AM
