Help with '00 FLHRI engine light
Old Sep 23, 2012 | 07:54 PM
Floppy Junk's Avatar
Floppy Junk
Default Help with '00 FLHRI engine light
Did a diag check with speedo and no codes. Engine light comes on with throttle and goes off if you pull in the clutch and idle down or are at a stop. Doesn't seem like there is a change in performance or anything but I don't want to risk not knowing for sure. Any ideas?
Old Sep 23, 2012 | 08:13 PM
dawg's Avatar
dawg
Did you check the codes properly for your year?
https://www.hdforums.com/forum/64418-post1.html
Old Sep 23, 2012 | 08:33 PM
Floppy Junk
Default Mine is a Magneti Marelli system. That says Delphi.
I checked holding the odometer button and turning on the ignition switch. Says all codes were clear.
Old Oct 2, 2012 | 07:48 AM
Floppy Junk
Problem solved. Previous owner replaced the battery and didn't tighten the terminals very well. Tightened them and light no longer comes on.
Kyle C Kirk
Nov 9, 2015 02:13 PM
97FXSTC13
Apr 18, 2014 09:16 PM
XMA
May 27, 2013 07:54 PM
AdrianVall
Sep 6, 2011 04:44 PM
SE120RG
Jul 20, 2009 08:00 AM
