Fuel pump noise, need help
Old Sep 23, 2012 | 11:25 PM
swillerbob's Avatar
swillerbob
Default Fuel pump noise, need help
My 06 street glide fuel pump whines when running, Same noise as whe you first turn the key on. It runs good other than a little caugh at low rpms every now and then. But I can defiantly tell its the pump. I have the tank off right now and checked the inside fuel lines. I do not see any holes. I am going to replace them since I'm already in their. Could the holes be so small I wouldn't notice them? I'm kinda confused about this. I thought for sure I nada hole on on of the lines.
Old Sep 23, 2012 | 11:38 PM
drukanfu's Avatar
drukanfu
There is gotta be a hole in your fuel pickup hose............or worst case scenario is bad bearings in the fuel pump.
Old Sep 24, 2012 | 04:02 AM
swillerbob's Avatar
swillerbob
Well we will see. I'm going to put new submersible fuel lines on today.
Old Sep 24, 2012 | 06:08 AM
toyman57's Avatar
toyman57
Default Same Noise
I have an 08 FLHT, makes the same noise. Thought it was just the fuel pump maintaining correct pressure for EFI. Bike runs fine. Dealer was just in the tank doing a recall. Let us know what you find.
Thanks
morleyz
Apr 4, 2014 12:21 AM
gant
May 24, 2013 07:41 AM
gant
May 9, 2013 09:52 AM
sammer4u
Oct 20, 2011 12:15 PM
wireman
Apr 28, 2006 04:47 PM
