Hydrogen Peroxide
Old Sep 27, 2012 | 06:26 PM
  #41
Verbal's Avatar
Verbal
Originally Posted by LeeH
Go easy on the Dihydrogen Monoxide -it's bad for environment, lol! http://www.dhmo.org/
Due in part to its widespread use in industry, Dihydrogen Monoxide (DHMO) is involved in many environmental incidents each year. While most are unavoidable given current technology, there can be little doubt that the presence of DHMO in each significantly increases the negative impact to the environment.
I had forgotten about this. Penn & Teller did a short video where they were asking people to sign a petition banning DHMO as it causes billions in damage yearly. People were signing left and right. It was hilarious! Do a youtube search on DHMO....
Old Sep 27, 2012 | 06:39 PM
  #42
turnerbend's Avatar
turnerbend
Just use plan water. Spray it on, wipe it off.
Old Sep 27, 2012 | 06:59 PM
  #43
RangeRat's Avatar
RangeRat
Had a half-dozen or so love bugs (not in full bloom yet) plus 3 or 4 major gut splatters here and there after a ride today. Did the peroxide deal using a damp mF cloth.
Sprayed the peroxide on the crud, left it alone for 15 seconds or so, and gently wiped with the damp mF cloth - ZAP... GONE as in POOF. Little black bodies, wings, and chit on the cloth but nothing left on the scoot. Couldn't even see where anything had been done - just the crud was gone.
I'm sold.
Old Sep 27, 2012 | 07:05 PM
  #44
Crazylegs's Avatar
Crazylegs
Yup, started this year with peroxide. Fifty % mix sprayed on followed by a hot soapy wipe. Really good results. Like most of us, the less rubbing the better on the whole bike.
Old Sep 27, 2012 | 07:24 PM
  #45
jjnoble's Avatar
jjnoble
Use it full strength, no need to dilute it.
Old Sep 27, 2012 | 07:38 PM
  #46
timmy gdawg's Avatar
timmy gdawg
After reading about it here on the forums, I had to try it ... Works FREAKIN awesome ! Thanks again HD Forums , you guys rock !!
Old Oct 18, 2012 | 03:22 PM
  #47
kyote's Avatar
kyote
Originally Posted by TKDKurt
Why not use Sulfuric acid? It's H2SO4 which is just water with this one little sulfur molecule and a couple extra oxygens....
(I think someone slept through high school chemistry...)
No.. I did not sleep through Chemistry. Do you mean to tell me you have never used it on a cut??
http://science.howstuffworks.com/inn...uestion115.htm
Old Oct 18, 2012 | 07:46 PM
  #48
Kokes58's Avatar
Kokes58
Learned something new today. Thanks for the great tip.
Old Oct 18, 2012 | 09:11 PM
  #49
Ray Lloyd's Avatar
Ray Lloyd
Default Tried It, It Works!
Ha! This is one of those great "Biker Lore" stories about something that actually works!
Detailed my bike yesterday after a 16 hour ride up to middle Wisconsin and back two day ago.
Bugs galore, even with the low temps-
On a whim, and not believing it would work, I tried the H Peroxide thing-
Works Great!
Maybe I'll package it as a "Bug Remover" solution----- I'll make millions!
Old Oct 19, 2012 | 03:45 AM
  #50
jjnoble's Avatar
jjnoble
Originally Posted by Armstronges
Try it for the first time today to help remove bugs i had acquired on my 800 mile trip to Eureka Springs, AR and all I can say is WOW! It works crazy good.
Yep, works good. Strong peroxide, like the stuff you use to whiten your teeth or industrial strength will have a chemical reaction with metal if left on long enough. What you buy in a bottle is much weaker stuff, only 2 or 3%, but still you should make sure you get it all off. I use it on the bugs then I use pledge, maybe bug slide or something similar for the shine and to take off any residue peroxide. It's a good combination. By the way bug slide by its self works well for taking bugs off, but it is very expensive and it takes much less of it if all you want is the shine it gives.
